Opentracker LCA
  • Thread starter Thread starter 19stang68
  • Start date Start date Feb 14, 2012
19stang68
17
Binghamton, NY
Feb 14, 2012
  • Feb 14, 2012
Hello all,
I have a 68 Mustang Coupe that I will be redoing the front suspension on in the Spring. I am planning on getting the Opentracker UCA but have a question on the LCA. They have a pair of MOOG LCA's they are selling for $160. I can get MOOG LCA's on Amazon for $50.99 each. Is there anything that Opentracker does to the MOOG LCA's that would make them different/better than the ones on Amazon that would justify the nearly $60 difference ?
Next question. Who sells a good quality standard spring perch? Since my car is not going to be driven aggressively I don't really feel that roller bearings are necessary. Thanks
Craig
joedokes28
104
Photown, Az
Feb 22, 2012
  • Feb 22, 2012
I purchased the entire front suspension form OT and couldn't be happier. The roller perches contribute to a much nicer ride. The difference in handling is amazing and I still have the 46 yr old POS factory steering box. If you are keeping the stock style suspension, I would highly recommend the roller perches and the heim jointed strut rods as these two components will provide the biggest gains.
JonK
276
Nashville (Smyrna), TN
Feb 22, 2012
  • Feb 22, 2012
No, the Moog LCA are the same from OTR as anywhere else you get the Moog part, John doesn't buy in as big a bulk or have the same supplier as Amazon, VA Classic Mustang, etc. so he can't give as low a price. When I called and talked to him he advised me to get them where they were cheaper.
The roller spring perches on the other hand are worth the change IMO, when you hold the stiff rubber perch in one hand and the roller in the other you realize how much bind the rubber ones cause. Many people comment on how much they feel the difference running over any irregular surface like train tracks or speed bumps that used to feel like a punch in the kidneys are now more of a glide over since the suspension can react so much faster to changes in surface and turns, etc. They're not just for racin'
Jon
65fastbackresto
1,229
AR
Feb 23, 2012
  • Feb 23, 2012
I have the roller perches too from John at Opentracker. Good upgrade with the adjustable strut arms too (makes alignments easy too). John is a good guy and wont sell you something you dont need, and his reputation is for being an honest guy goes way back in these forums.
Hack
1,945
Minneapolis
Feb 23, 2012
  • Feb 23, 2012
If you have ever tried to play with a set of stock roller perches you will understand why the OT parts are so much better. The stock ones bind so tightly it's really hard to even move them. I would highly recommend going with the OT parts.
19stang68
17
Binghamton, NY
Feb 24, 2012
  • Feb 24, 2012
Thanks everyone for the replies. Gives me something to think about in regards to the spring perches.
Craig
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Suspension A not-so-low lowering spring
  • Justin87
  • Mar 7, 2024
4K
Fox 5.0 Mustang Tech Mar 12, 2024
Justin87
O
Computer swap
  • Oakman
  • Jun 22, 2024
  • The Welcome Wagon
The Welcome Wagon Jun 22, 2024
Oakman
O
H
Hello all from my shop, Tod/ Tods Hot Rods, located in Moorpark CA 93021. Longtime 25 Yr Restoration/Performance Shop and Custom Builder Owner. Tod
  • Hot Rod Tod
  • May 28, 2024
  • The Welcome Wagon
The Welcome Wagon May 28, 2024
LILCBRA
