Opinions On This Head?
I think that is the perfect head for a supercharged Cobra and that horsepower goal. Trick Flow is good quality, and the 61cc chamber will help keep compression down.
Kurt
It's the smallest head Trick Flow sells. Notching depends on the cam you use. The twisted wedge design allows you to run a bigger cam than most entry level heads due to angle of the exhaust valve. You'll be fine without notching with the right cam.
Kurt
That's a good n/a cam designed for those heads, but you might be able to get a little more out of it by going to a blower cam. I would call a cam specialist and see what they recommend.
Kurt
