ordered the et street radials
  • Thread starter Thread starter Daniel50
  • Start date Start date Sep 12, 2005
Daniel50
716
Discovery Bay, CA
Sep 12, 2005
  • Sep 12, 2005
after the install of my cobra intake manifold drag radials are a must. my first gear is gone and so is the 1st to 2nd shift. just spins like mad. so i ordered a set of et street radials to throw on a pair of ten holes. whats the ideal tire pressure and what rpm to launch at at the track to be safe but still hook good? never been on drag radials before. guessing a 5 second burnout after wetting tires in the box, launch at 3500? with 18 psi?
Lyncher
434
  • Sep 12, 2005
I thought the ideal psi was 15...I could be wrong though
Curse
791
El Paso, TX
Sep 12, 2005
  • Sep 12, 2005
Those are questions you will have to find out on your own. Every track and car are different. My MT street radials hook like mad at 20 psi and a short burn-out. Only thing for sure is these tires rock
Daniel50
716
Discovery Bay, CA
Sep 12, 2005
  • Sep 12, 2005
yeah thats why i ordered them. i hear only good things and they hook crazy good. hoping for 1.8 60 fts. ill start at 20psi and go from there.
stroked8e5
28
  • Sep 12, 2005
I just got my pair today. Heres what M/T says on the website.
Inflation Pressures
On the racetrack DO NOT use starting pressures below 11 psi.
Recommend pressures for:
P295 and larger sizes: 11-14 psi
P275 and smaller sizes: 12-16 psi
On the highway we recommend running 75% of the max psi as notes on the sidewall of the tire.
Burnouts
The tread compound used in the ET Street Radials is designed to heat quickly and does not require a heavy burnout. Continue the burnout until the engine starts to pull down. We do not recommend a dry hop after the burnout.
Bead/Wheel Slippage
Some bead/wheel slippage may result during the course of a 1/4 mile (or 1/8 mile) drag race. This is normal.
Use of Bead Screws
If you elect to use bead screws, we recommend the installation of 16 equally spaced screws per bead.
Bead-Lock Wheels
For drag strip speeds in excess of 180 mph, Bead-lock wheels are highly recommended.
This is Mickey Thompson STREET & STRIP TECH BULLETINS Technical Bulletin #7. For more information regarding Mickey Thompson Performance Products ph: 330.928.9092
maverick0716
3,924
Chilliwack, BC, Canada
Sep 12, 2005
  • Sep 12, 2005
They're awesome tires, I'd be hopeless at the track without them. I launched at around 3000 rpm when I got my 13.2 and only had a 1.98 60', so you may want to launch higher.....I know I'll try next time, just hopefully I don't break anything.
jaymac
995
Northern Mass
Sep 12, 2005
  • Sep 12, 2005
No flames please, but I spoke w/ 2 different techs at Mickey Thompson, and they both siad Et Streets are better suited for 5 speeds, and the Radials are better suited towards automatics.
Not even my own humble opinion, but straight from the horses mouth.
I know alot of you guys are running them successfully, and good for you for that, just lettin' ya know what I was told!
Don't shoot the messenger..
slo65
448
Southern California
Sep 12, 2005
  • Sep 12, 2005
best i've pulled bone stock suspension (sway bar removed) was a 1.80, i then got full length subframes, but my track lock went out that night, so no more running till it gets a rebuild (got the rebulid kit today) also lca's going on, i'm looking for consistant 1.7's
btw i have the "Little" 235/60/15's (ten holes) they hook pretty good, i probaly do alonger burnout than i should, but i like smoke , i launch around 4k
Black1987Stang
1,422
Jersey Shore
Nov 23, 2005
  • Nov 23, 2005
What do all of you think of the M/T ET street radials? Can they be used in the rain or daily drivers? Thanks
M
Mike92GT
583
Florida
Nov 23, 2005
#10
  • Nov 23, 2005
  • #10
my buddy has a set on his '04 GT. They were ok in the rain when they were brand new, but after just a couple thousand miles they are showing quite a bit of wear. Last time I was in the car, we we cruising at about 50mph in the rain and the car hydroplaned and did a 360 in the middle of the road. Luckily there was no other traffic at the time, and he was able to avoid hitting the guardrail. I wouldn't recommend them for a daily driver. Nittos or BFG drag radials seem to be a little harder compound and might be better on a daily driver, but I'm not sure
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
Nov 23, 2005
#11
  • Nov 23, 2005
  • #11
My BFG's were horrible in the rain at 50mph when they were worn down a little. I do not reccomend it at all.
rsw007
469
Lexington,SC
Nov 23, 2005
#12
  • Nov 23, 2005
  • #12
i run 15lbs no problems even on the 90 shot. vids in sig. 275/60r15's have a friend with same size cut 1.37 on them.
5.0Grunt
Banned
Nov 22, 2005
where ever I may roam
Nov 23, 2005
#13
  • Nov 23, 2005
  • #13
My Nittos were just as good if not "better" then my regular radials in the rain,and last between 10-15,000 miles..The new M/T radials are the mack daddy of DR's (on the track)
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 23, 2005
#14
  • Nov 23, 2005
  • #14
What wheels are you putting them on? Pony wheels? Let us know how they work, i'm looking to pick up a pair down the road to replace my nitto dr's. Hopefully they'll hook a 4.30 geared 347 good
Daniel50
716
Discovery Bay, CA
Nov 24, 2005
#15
  • Nov 24, 2005
  • #15
drive around daily on mine and never have any problems they handle better than my kuhmos did
P
PRO50SC
1,012
Olney, Maryland
Nov 24, 2005
#16
  • Nov 24, 2005
  • #16
15psi and drop the hammer at red line!!!
Jkstang78
1,510
long island N.Y.
Nov 24, 2005
#17
  • Nov 24, 2005
  • #17
You know this is really a tuff ? to answer. Because it all depends on the track & How the car is setup. Do you have drag suspension?. I had my old car hooked up with drag stuff and ran the old E/T streets and use to run about 12lbs and I use to leave the line at 6000 rpms. Its really about how you have you car built. I had a lot of good parts on my car and never once broke at the track. You'll never get anywhere if your on a budget build up. Do it right and do it right the first time.
Black1987Stang
1,422
Jersey Shore
Nov 24, 2005
#18
  • Nov 24, 2005
  • #18
I think ur talking to me right, Im putting them on my pony's, although i think ill be going with the Nitto's. I need them to last long over hooking up good, ya know.And theyre also going on a daily driver. What are they called Nitto 555 or something or just Nitto drag radials? Thanks
Grn92LX
Fidanza Man!
6,819
64
129
New York
Nov 24, 2005
#19
  • Nov 24, 2005
  • #19
I was asking Daniel50
The tires you're asking about are the nitto 555R's.
J
  • JRC99
  • Apr 19, 2025
2K
JRC99
J
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
  • Locked
“Doing stuff the wrong way for the right reasons”: A related stupid story.
  • CarMichael Angelo
  • Apr 26, 2020
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2020
a91what
Build Thread 1978 Fairmont. I bet somebody back home’s thinkin’…I wonder why he don’t write..?
  • CarMichael Angelo
  • Aug 27, 2020
  • 137 138 139
3K
397K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 7, 2025
Rdub6
Extreme Street Racing
  • RangerJoe
  • Mar 19, 2018
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2018
RangerJoe
