OT- 1000 posts.
super302 said:
heres some tech joe: how do i change my muffler bearing w/o setting off teh check engine light? :D
I almost got 900
You have to get that stuff in a can that is located in the store between the frequency grease and the blinker fluid. Note: Not to be confused with brake fluid for air brake equipped vehicles though. :D
What brand of blinker fluid should I go with? My car is at its 5000 mile change of the fluid and I dont know if I should run normal or synthetic blinker fluid. Also, does the color of the fluid matter?
free post :banana:
free post :banana:
Synthetics all the way baby and yes the color does matter. The premium stuff is a bright yellow. If you go too long without the a fluid change the blinker will start switching erractically. If left unattented the light will start to turn an orangish color and eventually turn brown. Those with clears should use normal fluid since the additives in the sythetic will cause your lamp to turn yellowish over time. :lol:
