OT/ sway bars
  • Thread starter Thread starter WORTH
  • Start date Start date Aug 21, 2004
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 21, 2004
  • Aug 21, 2004
Anyone have a connection for a decent deal on splined type swaybars? I can't find a stock swaybar I can use in the front of my '46 pickup because there isn't alot of room up there. i found a few places to buy them, but they get all the money for them. The complete setup is around 200 bux, I was hoping for something a bit cheaper.
EDIT: I had a revelation while pouring a cup of Java. I have a couple of old swaybars that I was experimenting with in the garage and realized that one of them was rusty,(dim light in brain turns on), so I went out there and put it in the band saw, and I can cut it. I always thought spring steel was to hard to machine. So if I can cut it I can machine it and make my own out of any straight swaybar over 35 inches long.
My only question now is can I weld it without destroying it's properties?
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 21, 2004
  • Aug 21, 2004
Although it may be possible to weld spring steel, I wouldn't. What you can do is make some bars to go from the ends of the bar to the suspension, and have them broached square. Any decent machine shop should have a set of broaches which for those that don't know is simply a square cutter forced through a drilled hole. Anyway, once you have the hole squared up, grind, file or otherwise shape the end of the bar to tightly fit the square hole. Next, cut a slot in the bar, and drill and tap a hole for a pinch bolt to clamp the end bars on the sway bar.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Aug 21, 2004
  • Aug 21, 2004
Dont have a broach but I have a nice hendey shaper Thats a good Idea I can do the bar and the arms with the shaper. Thank you sir
zookeeper
3,415
63
109
Rogue River, Oregon
Aug 22, 2004
  • Aug 22, 2004
Sounds like you already know your way around machine tools, good luck and let me know how it comes out.
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
So confirming what I need to do to put a '88 CV 302/AOD in my '65 A-code.
  • 1320stang
  • Apr 19, 2023
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2023
1320stang
P
Sway bar bolts?
  • Parzivahl
  • Mar 22, 2021
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 25, 2021
DoHxBoY
D
302 Engine build questions
  • Vulpes5.0
  • Apr 19, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 10, 2022
LEEDAY Boss
Car sways all over the road
  • Smurfstang88
  • Apr 4, 2021
9K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 10, 2021
HemiRick
