other uses of the turbo?
I candy
597
Honolulu
can you use the turbo from this car on anything else?
how much boost does this turbo make? only reason is that i can yank it off at the junk yard. but not sure if its even worth it.
ahh sorry didn't know that.
its from a 89 all i had was the vin. it says its a 2.3 4cyl. but not if its a turbo.
but i'm assuming it has to be cause the car has 5lug rear end with disc brakes. and who would do that if it wasn't modified with a turbo??? the car is at the junkyard. and i was wondering if the tubo alone is worth something.
i ain't going to take an engine that i don't know nothing about espeicially if it may not run.
If its modified who knows. It could be parts from a stripped SVO, god rest its soul, or it could be an engine stripped out of a turbocoupe, which means it is either a T3, trim depending on year, or an IHI turbo. The T3 would be the more desireable of the two, or who knows it could be a cheapo ebay turbo or wherever the previous owners imagination took him. Unless you look at it yourself theres no way to know on a modified car...
