Drivetrain overdrive acting weird
USCGunner
60
12
28
Idaho
91 fox 5.0 convertable my od works but the shift is rough when shifting in. It feels like i loose power for a sec then it seems to pick back up. I do not know when service was done on the trans. I purchased it 3 years ago with 102000 and have put about 1000 miles on it. Any suggestions would be appreaciated.
  • Sponsors(?)
John Dirks Jr
there is enough sticking out to grab on to
5 Year Member
Jun 28, 2013
2,791
1,180
174
56
Maryland
You can check the fluid and throttle valve cable adjustment and that’s about all you can do with the AOD externally. Even then, if either of those were a problem it would also be acting up in other gears.
The overdrive is the weakest link on the AOD and it’s usually what fails first. If you find yourself needing a rebuild, you can upgrade the reverse drum, band and sprag from the stock 1.5” to 2” from AODE or 4r70w. It would also require a compatible sun gear shell from the same or similar donar unit.
Here’s an example of the 2” drum
https://cobratransmission.com/aod-a...MI6fTigOu65AIVDl8NCh2tLQ6dEAQYASABEgKnJ_D_BwE
Here’s the sun gear shell
Using these parts in a quality rebuild will substantially the durability of the AOD transmission.
John Dirks Jr
5 Year Member
Jun 28, 2013
2,791
1,180
174
56
Maryland
You can nurse the ailing od by keeping the shift selector in D for slower around town driving like any speed 55 and under. This will prevent unnecessary up and down shifting in and out of od.
When you want od for higher speed driving, take it up in D, let off the throttle a little and move it to od. It will make a more gental upshift and help it hang on to life longer. I know this does not fix it, just buys you some more time before the inevitable rebuild.
Thread starter Similar threads Forum Replies Date
Sampinator Hard downshift OD to 3rd 1996 - 2004 SN95 Mustang -General/Talk- 1
H Overdrive button wires go to ? 1994 - 1995 Specific Tech 1
A Drivetrain Overdrive for my AOD only works sometimes Fox 5.0 Mustang Tech 2
J Need help identifying 4.6L accessories + intake manifold problem + overdrive wiring problem 1996 - 2004 SN95 Mustang -General/Talk- 0
SteveG94GT 94 GT OVERDRIVE BUTTON 1994 - 1995 Specific Tech 0
wolfheads Overdrive issues 1996 - 2004 SN95 Mustang -General/Talk- 0
B Drivetrain Mustang T5 Overdrive Transmission Bolt Pattern SN95 V6 Mustang Tech 0
E Re-gear Vs Overdrive 1965 - 1973 Classic Mustangs -General/Talk- 9
B Overdrive Unit In A Gt 2010 - 2014 Specific Tech 2
Grabbergreen Overdrive Complete Transmission For 1970 Ford 1965 - 1973 Classic Mustangs -General/Talk- 2
L Drivetrain NO OVERDRIVE A4LD 89 MUSTANG 2.3L (N/A & Turbo) Tech 3
JonezySN95 Drivetrain Overdrive Issue 1994 - 1995 Specific Tech 4
3 Overdrive bypass switch no working SN95 V6 Mustang Tech 2
LaserSVT AOD has no overdrive Fox 5.0 Mustang Tech 3
J 40th Anniv ? about overdrive Special Production 3
R INNOVATIVE WEST 8 RIB 10% overdrive Engine and Power Adder Parts 0
moneypit94 msd overdrive alternator pulley? 1994 - 1995 Specific Tech 8
mhjo Overdrive for C4 Classic Mustang Specific Tech 12
M overdrive switch SN95 4.6L Mustang Tech 1
mhjo Overdrive for C4 Classic Mustang Specific Tech 22
R Ford Windstar Tranny won't stay in Overdrive Other Auto Tech 9
Edster Which overdrive tranny fits a 66 w/o cutting? Classic Mustang Specific Tech 13
scupking 4r70w Transmission Overdrive issue? SN95 4.6L Mustang Tech 3
J overdrive light please help SN95 4.6L Mustang Tech 17
68GT500KR_Vert Paddle Shifter for C6 & GearVendor Overdrive Classic Mustang Specific Tech 3
5spd GT No Overdrive in stock '93 AOD? Fox 5.0 Mustang Tech 1
S Overdrive Crank Pulley SN95 4.6L Mustang Tech 4
T AUTO OVERDRIVE Classic Mustang Specific Tech 8
D Steep rear end gears (4.10s) compensated by replacing overdrive in a T5? Fox 5.0 Mustang Tech 32
96SCstang under/overdrive crank pulley SN95 4.6L Mustang Tech 3
A 4r75w with overdrive SN95 4.6L Mustang Tech 2
asecretfile Slipping out of Overdrive?? Fox 5.0 Mustang Tech 2
Chythar For those of you that want a 1993 Cobra water pump pulley (overdrive pulley) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
C AODE overdrive question......... 1994 - 1995 Specific Tech 4
kalvick Overdrive buttons doenst work. I need help SN95 4.6L Mustang Tech 2
B overdrive just quit? SN95 4.6L Mustang Tech 5
B AOD trouble, not shifting to overdrive Fox 5.0 Mustang Tech 5
4.6boy overdrive ? SN95 4.6L Mustang Tech 3
B overdrive unit? Classic Mustang Specific Tech 16
cervinistang Overdrive VS. Drive 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
B v2od overdrive US Gear Classic Mustang Specific Tech 4
woody258 ASP overdrive alt pulley Fox 5.0 Mustang Tech 4
68keyblr Gear Vendors Overdrive - Anyone got it ? Classic Mustang Specific Tech 9
monte87 Whats part# ASP Alt./Overdrive pulley??? Fox 5.0 Mustang Tech 8
AnthonyR23 Overdrive Pulley... Belt Tensioner.. Help? Fox 5.0 Mustang Tech 5
AnthonyR23 Overdrive Alternator Pulley... anyone used a capacitor Fox 5.0 Mustang Tech 3
metroplex Overdrive Light Flashing On and Off SN95 4.6L Mustang Tech 5
bdepedro Overdrive-gear splitter vs. T-5 advice needed Classic Mustang Specific Tech 10
B Which overdrive gear is best? Classic Mustang Specific Tech 9
bad68coupe Who makes good overdrive units Classic Mustang Specific Tech 11
