coolant reservoir questions
Ok i got a hold of some extra 10 ga. t-304 polished stainless at work, and i made me an overflow tank, i have never liked where the stock one was anyhow.
My question is, if it is airtight will it allow fluid to be pushed in it, or even allow the fluid to be sucked back up by the radiator when needed.... I can put fittings or whatever i need to on it, just kinda need to know what to do......
Does it need a vent, i already bought a drain ****, so that i can empty it.
Wouldn't it be best to locate the fitting for the coolant hose on the bottom of the thing so that it would recirculate easier.....i could also run some small diameter stainless tubing from the bottom to a fitting on top if need be, i have some of that as well.... 3/8 diam....
just a lil help needed if anyone knows.....
thanks.....
thanks.....
