  • 1994 - 1995 Specific Tech
overheating problems
  • Thread starter Thread starter fordtech28
  • Start date Start date Jul 3, 2006
F
fordtech28
312
Riverside Cali.
Jul 3, 2006
  • Jul 3, 2006
Here's one for all the guys that are having overheating problems the stock computer turns on the fan waaaay too late on our cars and as our cars get older the hotter they want to run.If you put in a 180 thermostat and run this mod your car temp wont go over 195 if set correctly and if your car doesnt have anything major wrong with the cooling system .I have this on my cobra for the past 3 years with the stock radiator and then with the fluidyne it works awsome I only put the fluidyne because I plan to make big mods to the motor soon and extra cooling doesnt hurt keep in mind you use your stock fan and the high speed wire on your fan it will cool down quick believe me and use the recommended wire and you should be fine this is cheaper than getting a tune just to fix the fan problem this is if you have the stock electric fan or if you are planning to put one on
http://www.fordmuscle.com/archives/2003/02/electricfan/index.php
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jul 3, 2006
  • Jul 3, 2006
Not to be rude, but punctuation would help make that extremely long run-on sentence legible. The 94-95 Mustangs (V6 and V8 alike) both use a two-speed electric fan already, and the write-up in the link you provided would have no bearing on the aforementioned model years, as this is the original equipment fan on these cars. This should possibly be posted in 5.0 Tech since the Fox Mustangs still used a fan-clutch until 1993. Your Cobra would have had this system from the factory.
F
fordtech28
312
Riverside Cali.
Jul 3, 2006
  • Jul 3, 2006
please read again this is just FYI
OrangeMustangGt
1,976
Cape Cod, MA
Jul 3, 2006
  • Jul 3, 2006
i agree. I've always installed 180 in my car and NEVER have a problem.....it always runs in the N on normal.
HISSIN50
34
129
Jul 3, 2006
  • Jul 3, 2006
A much much better way to do it is to run a variable fan controller (a la DcControl.com ). THe unit absolutely rocks and makes the relays we use now look antiquated.
As Matt said, that article is very popular with the fox guys. They just use high speed on the fan.
M
Idle control problems
  • miser143
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 29, 2026
DadLife0724
Surging/stalling! problem or tune?
  • djj62478
  • Oct 4, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 14, 2026
KRUISR
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
  • Mindseye007
  • Aug 16, 2026
Mindseye007
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
