  • 1994 - 1995 Specific Tech
Overheating problems
  • Thread starter Thread starter 5.0_GT_kid
  • Start date Start date Feb 2, 2007
1 of 2 Next Last
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 2, 2007
  • Feb 2, 2007
UPDATED @ POST 12​
Alright, so here is my problem. I'm driving home from Lakeland last night after dropping my girlfriend off at her college. On the way, my upper radiator hose developed a split, but I made it home before the car got too hot.
Today I replaced the hose and went to drive back to lakeland to see her, and after less than 5 miles the car was already getting close to overheating, so I came back home. The funny thing is that the car never acted sluggish or started pinging.
Does anyone know what the deal might be? Did I forget a step in replacing the radiator hose that might have fouled everything up? Any and all suggestions needed.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Feb 2, 2007
  • Feb 2, 2007
maybe theres some air left in the system
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 2, 2007
  • Feb 2, 2007
Ok, how would I fix that problem?
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 2, 2007
  • Feb 2, 2007
bump
Car Nut
1,176
Snellville, Georgia (Atlanta area)
Feb 2, 2007
  • Feb 2, 2007
A haynes or chiltons manual has info on getting air out I believe. Can't get my hands on the book right now, but I'm sure its there.
Maybe a search on here will get you info. Pretty sure that info is here, but maybe not.
If air is not the cause, maybe the thermostat is not opening. If it hasn't been replaced in a long time, it might not be a bad idea to replace it.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 2, 2007
  • Feb 2, 2007
I'm gonna flush the coolant and replace the thermostat tommorrow, hopefully that fixes it.
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 2, 2007
  • Feb 2, 2007
I'd replace the thermostat like Car Nut mentioned, but I agree you probably still have air in the system. Park the car on an incline or put the front on stands/ramps so the radiator fill is the highest point of the system when you're filling it. That should be the easiest way to ensure the air gets out since it'll want to find the highest point.
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Feb 2, 2007
  • Feb 2, 2007
Just a friendly tip... If you're going to the store tomorrow to pick up a thermostat, check your lower radiator hose before you go. If your upper hose split because of old age then there is a possibility that your lower hose may be ready to fail as well. Why not replace it while you have the system down.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Feb 2, 2007
  • Feb 2, 2007
Did you remember to refill the radiator and overflow bottle after you replaced the hose? I am 100% sure you lost a great deal of coolant when the hose split.
Scott
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 2, 2007
#10
  • Feb 2, 2007
  • #10
I checked the lower one and it seemed ok to me.
Scott
Yep, I refilled both.
HISSIN50
34
129
Feb 2, 2007
#11
  • Feb 2, 2007
  • #11
When I burp a system, I generally do as Matt outlined but then let the car idle with the rad cap removed. You have to be very careful of hot coolant spewing out. You can renew coolant as air is removed. You can also see when the t-stat opens and coolant starts moving across the coil.
Good luck.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 4, 2007
#12
  • Feb 4, 2007
  • #12
Ok, today I replaced the upper radiator hose again (the new one i had gotten had a slit in it, replaced free of charge) flushed the coolant system, replaced the T-stat/gasket with a stock replacement.
I had the front end of the car jacked up and let it idle for a few minutes with no radiator cap so the air could escape. I took the car around my block 2 times and when I got home the temp gauge was already on the "A"
What is so weird is that the when this all started, my car got so hot coming home on the bridge that the check engine light came on, but my car was never pinging or acting sluggish.
Any ideas WTF is going on here?
HISSIN50
34
129
Feb 4, 2007
#13
  • Feb 4, 2007
  • #13
When I purge air, it normally takes 20 minutes or so. I let the car idle long enough to have the T-stat open (this is when some decent air comes out). Otherwise, if air is still in there, the ECT reading can be off, which means the fan doesnt come on, etc.
Good luck.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 4, 2007
#14
  • Feb 4, 2007
  • #14
Ok, I'll try that.
sade04
97
Lansdale, PA
Feb 4, 2007
#15
  • Feb 4, 2007
  • #15
when im letting air out of the system, i usually squeeze the upper rad hose a few times. i dunno, doing that usually gets the air out pretty quickly.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 4, 2007
#16
  • Feb 4, 2007
  • #16
Ok, I'll give that a shot as well.
Q
quick1320
12
#17
  • Feb 5, 2007
  • #17
mine did something similar found out the fane control was no good check to see if fan comes on check connections first maybe water spraying on it hurt it
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 5, 2007
#18
  • Feb 5, 2007
  • #18
Fan is running still.
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 5, 2007
#19
  • Feb 5, 2007
  • #19
Bump
5.0_GT_kid
20+ Year Stangneter
Apr 18, 2004
1,155
Largo, Florida
Feb 5, 2007
#20
  • Feb 5, 2007
  • #20
Quick question...how will I know when the system has been completely "burped"
1 of 2 Next Last
Engine 1986 GT Overheating issues
  • 86 5O GT
  • Jan 25, 2026
Fox 5.0 Mustang Tech Jan 29, 2026
86 5O GT
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
M
1997 Mustang GT Overheating Issue
  • Mustang1988!!
  • Sep 3, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
squeak93
O
2001 mustang gt overheating
  • orinsmiley11
  • Jul 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 17, 2025
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
