So I'll start this with the list of my recently changed/upgraded items, and I'll go from there:
-Upper and lower radiator hoses (the lower one is a bitch to change!!!!)
-New expansion tank cap
-New 14" Mishimoto Performance fan (set to come on at 140* with SCT Tuner)
-New factory replacement thermostat and gasket.
Now to my saga, and my plan (unless I'm told different). With all this the car still likes to cruise up to between the M and the L during traffic. I know mustangs typically run a little hot, but damn I feel this is too much. The car will never surpass the normal range. Nor will it billow out smoke from the engine, but thats too hot for my personal comfort.
There is a few little things that I've noticed, and maybe you can diagnose my problem. If I'm not mistaken, my upper radiator hose, should be hard when I run the car to normal temp, should it not? Mine never gets hard, but it is hot as all hell to the touch. Also, sporadically the car will leavea puddle of coolant underneath it. Now, it doesn't happen often at all. Just every couple of weeks or so, and it seems to be coming from the bottom high pressure connection on the radiator. I know this is something I need to fix, but I'm sure it isn't the cause of my problem.
My plan of action, is buying a Mishimoto Aluminum Radiator, a Moroso coolant expansion tank, new Mishimoto silicon hoses, an Electric water pump, and a Mishimoto racing thermostat.
Hopefully with this, it will fix it. Unless you guys tell me something I can do to fix it with out all that.
Thank you in advance.
__________________
96 Mustang GT Auto
-K&N Cold Air
-O/R X Pipe
-Flowmaster Cat-Back
-3.73's
-17x9/10.5 Athracite Bullits
-Mishimoto 14 in. Electric Fan
-SCT SF3 Tuner- With Bama Custom Tuning
__________________
96 Mustang GT Auto
-K&N Cold Air
-O/R X Pipe
-3.73's
