- Mar 31, 2005
- 427
- 0
- 17
I posted the same in the general 5.0 section, but no one there seems to be as helpful as the group of guys/girls around here.. hmmm but anyways, it really does belong in the general 5.0 section, even though all questions really are on the powertain, so feel free...post away
My buddy owns a 90 LX (5-0) with nothing more than full bassani exhaust w/ LT's, 3.73's w/ Auburn diff. weld's w/ bfg drag radials, Tremec tko trans, and 70 mm t/b and maf... he has plans on buying trick flow stage 1 TW heads w/ TF track heat intake, and Vortech v-1 s-trim s/c running at 12-15 lbs boost, and full aeromotive ecternal fuel pump and fuel system. it will have a custom chip and the cam is as of now unknown. my question is this... the local shop wants to sell him the aeromotive kit that includes 60 lb injectors!!! isnt this overkill, even for this setup? and also, is this way too much power to be putting on a stock block and bottom end?? what suggestions do you all have to help tame this set-up down? and also what might the weak links be? obviously stock axles and suspension for starters...
oh btw, the car has only 65k miles and is in mint condidtion otherwise
thank
-Kyle
thank
-Kyle
This has always been a mystery to me
Back on track here
