P-51 intake manifold on PI headswapped 98 GT??
98blackstallion said:
will this intake fit my pi headswapped 98 gt? I have full bolt ons with stage 1 cams and stock unported heads. How much Hp would i be able to pull with this intake.
I don't see why it wouldnt. I'm guessing you would have to tap a hole in the coolant runner for the 2nd temp sensor, and then it should bolt up to your PI heads just like it would to a 99-04 2V. I'm not sure about the gains - intuition tells me they would be the same or a little higher than bolting the P51 onto a similarly modded 99-04; any extra power your motor sees would be from the compression, unless you've taken care of that by using a bigger dish in your pistons. Just my thoughts, I'm sure someone else could give you a better idea though!
