mr. jones1
you are entitle to your opinion.
The plates I use are 1/8" thick so the total lift of the manifold is 0.373 measured. Now subtract the standard gasket and you have a 1/4" lift at the injector. Much less that the other plates.
If the plates seal with out RTV (and they do) whey install a manifold without them. They do blend the ports better than without them. I only go involved with making them because I did not want to pay $650 for the kit and I did not want to take any risk with leaks. I spent alot of time making sure the water port matching would seal to both gaskets.
If your budget can't handle the cost of my plates you probably should not be modifiing the car in the first place.
Just my opinion
Just my opinion
Couldn't be happier!!!!!!!!
