  • SN95 4.6L Mustang Tech
P0153 code
  • Thread starter Thread starter bigbird04
  • Start date Start date May 19, 2011
bigbird04
106
Decatur Al.
May 19, 2011
  • May 19, 2011
04 gt bbk off road x pipe got code p0153 earlier reset it tried three key cycles and not coming back any thing to worry about ? I ask because it seems like the passenger o2 sensor wire was tight when I installed off road mid pipe.
fast97gt
1,082
north carolina
May 20, 2011
  • May 20, 2011
need MIL eliminators. o/r-x=no cats=check engine light.
trinity_gt
3,125
81
99
Canada
May 20, 2011
  • May 20, 2011
P0153 is a slow-response error with a front sensor so the lack of cats isn't involved.
Did you get any anti-seize on the O2 sensor when you installed it? It may also be caused by anti-corrosion oils being burned off and "temporarily" fouling the O2 sensor.
BTW, that wire being tight is not good. The engine moves a lot during acceleration and if the wiring is tight is can be pulled enough to snap. Make sure you've got enough slack...
bigbird04
106
Decatur Al.
May 20, 2011
  • May 20, 2011
I do have mils on the rear o2s. I do need to either buy, or make some exstensions for my sensors. Are the rear o2 sensors the same as the fronts ? I ask because the used x pipe I bought had nearly new ones in it. If they are the same I have a spare set. I drove a little over 20 miles to work this morning with no codes. The car seems to be runing fine, but I have feeling it could have somthing to do with the wires being so tight. I'm due an oil change so I'll extend those while I'm at it . Thanks for all the help.
L
loveN2O
  • May 20, 2011
the rear o2's are different then the front the fronts or up stream sensors should have a part number ****-9F472-*** i put the astrics because the first and last sets of numbers will differ depending on the vehicle the 9F472 number is fords number for O2 sensors. the rears or the down stream sensors will be ****-9G444-***. my guess would be the sensors on your car may be upstream 5C5Z-9F472-AA and down probably 5W6Z-9G444-AA. dont buy any sensors from your local parts store go with the motocraft parts its only a lil more money and its worth it. also its possible that your MIL's are not working if you have a tuner for the car then use the tuner to disable the rear sensors it will work the best. hope that helps some bro
fast97gt
1,082
north carolina
May 23, 2011
  • May 23, 2011
Oops sorry I looked at the wrong number, trinity has the rite theory on tight wires. You defenitly need extensions.
  • Gulftown980x
  • Jul 29, 2026
squeak93
Tuners come on inside
  • squeak93
  • Feb 13, 2026
  • SVT Tech Forum
SVT Tech Forum Feb 20, 2026
squeak93
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
R
bbk shorty header to mid pipe gasket
  • randyyy
  • Sep 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- Sep 29, 2025
randyyy
R
Engine Multiple o2 sensor codes, car runs terrible
  • 02newedge
  • Jun 12, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
squeak93
