Hi there
Can anyone share the diagram wiring of the Canister Purge Valve ? I have replaced like 3 times on one month and still i have ECL on the dashboard with performance issue. i tried to check the fuse 47 but its OK. there is power on the wire socket ( 13 volts at the end yes but the valve is still no click/ stay closed !) . The valves i have i confirmed its working when connect it to the battery.
at this point i suspect a wiring issue/ground somewhere or the PCM is byebye. i want to trace the wire but i sow it going under the body of the car. to where? i dont know.
So, anyone can share the wire diagram so i can trace for electric or ground issue ?
