  • SN95 4.6L Mustang Tech
p1000 I need help I can't clear this
  • Thread starter Thread starter elias101a
  • Start date Start date Jun 2, 2011
E
elias101a
14
  • Jun 2, 2011
can't clear this code and i need to pass emissions(smog) and inspection. i've driven 200+ miles, i have mil elims. in
trinity_gt
3,125
81
99
Canada
Jun 2, 2011
  • Jun 2, 2011
P1000 is a readiness code. It's intended to demonstrate that a lack of error codes logged correlates with the PCM having checked all parameters. In other words, after codes have been cleared, the PCM needs to see a certain pattern of driving called a "cycle" that allows it to exercise all the testable parameters and sensors. The idea is to prevent people from erasing the codes and then rushing to an emissions test with no codes in memory. P1000 is the PCM telling the inspector that "Yes, there's no codes but I haven't checked everything yet..."
Simply driving 200kms may not be enough to fulfill this requirement. You need to drive the car in a way that satisfies the Ford OBD-II driving cycle, seen here:
Ford Motor Company Driving Cycle
N8Dogg98
3,872
238
184
MN
Jun 2, 2011
  • Jun 2, 2011
I am so glad I don't live in a state where emission testing is required... what a freaking joke... New cars are such that most will trigger an engine light if/when there is an issue with the emission system. Most car owners will get their vehicles fixed.
I seriously doubt the remaining 0.02% that install cat-less mid pipes or disregard the engine light are doing much, if any, harm to the environment
/rant
E
elias101a
14
  • Jun 2, 2011
i followed the drive cycle three times, i can't get rid of this code, and i've got smog and inspection over due because of it
E
elias101a
14
  • Jun 2, 2011
/rant
i'm jealous, and yeah i agree, as long as cars come stock with cats, 98% will leave them on
N8Dogg98
3,872
238
184
MN
Jun 2, 2011
  • Jun 2, 2011
99.8% of people will leave them on... damn tree huggers make the life of a car enthusiast incredibly difficult
E
elias101a
14
  • Jun 2, 2011
+1, if they didn't drive prius's they might understand
GTMUSTANG2000
  • Jun 3, 2011
when clearing codes at work i have noticed, we tend to see the p1000 code come up when a scan tool has been used, and then unplugged without backing out of the program and shutting the scanner off first. you may try to go to a shop you know ask them to scan the car and if no other codes are there, ask them to first exit out of the program shut the programmer off, then turn off car and disconnect scanner. i will say that in most cars the p1000 code by itself won't usually turn the light on
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Jun 3, 2011
  • Jun 3, 2011
I am assuming the OP is in CAlifornia since he keeps calling it a smog check, and IIRC we are the only state that calls it that. If that is the case, a present P1000 code is an immediate failure.
OP: what monitors have not run yet?
wmburns
SN Certified Technician
Aug 14, 2009
5,892
514
204
Houston Texas
Jun 3, 2011
#10
  • Jun 3, 2011
  • #10
The P1000 is not really an error code. It means that some monitors have not completed. There are valid reasons for some monitors to remain pending. Especially during cold weather or say above 5,000 feet.
I was not aware that any state would not pass the car where the only code is P1000 AND no MIL present.
midnightdriver
443
Northern California
Jun 3, 2011
#11
  • Jun 3, 2011
  • #11
+1, The reason the code is still coming up is because you may be having a faulty sensor or something else with the computer is going wrong.
Friend had a code, cleared it with his scanner several times on his truck and had this code for over 2 weeks. What got it to go away? He simply cleared the code, turned the scanner off and disconnected the battery for a half hour(lunch). Then we reconnected the battery, and followed the drive cycle exactly, I mean exactly. Country roads are really nice for this. You can't just clear the codes and go in some cases, I would reset the PCM as well and retry.
As far as Codes vs. Smog, I know in Cal you are allowed to have one code when you go in for smog.
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
H
97 cobra maf sensor help
  • Hopper1979
  • Oct 16, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 17, 2026
CAMTWO1070
T
Looking for some help with 2006
  • thedudeillest
  • Mar 16, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 20, 2026
