SilverBullet00 said:Is there a way I can test to see if my PCM is still good? When I burned up my 02 sensor I never threw a code. Also, how can I tell if I have a bad IAC or TPS? I can unplug my TPS and drive around town and not see a difference.. But when I unplug the electrical connector for the IAC the car wont stay running. BUT when the car is running at 2000rpms and I unplug the hose from the IAC it is still sucking a lot of air.... should it do this?
Thanks for your help man, Im starting to go crazy with this thing not running right!
being able to unplug the TPS and drive it is normal.. in EEC V the TPS is a secondary sensor the PCM can work around a bad TPS easily. So I don't think your TPS is bad.
The car dying with the iac unpluged is normal. and at 2000 RPM's the PCM will still be comanding the iAC opened atleast 25 percent so it's normal to feel air there.
I still think the tune is your problem. the headers glowing orange means that thing is running lean as hell.. in fact you might damage the motor if it has not gotten damaged already.
Honestly without live data and without proper diag equipment I really can't pinpoint it for you. As a last ditch effort before you bring this car to a LOCAL tuner you can try getting a PCM out of another car and see how it runs.
I know your tuner has a great rep but without being there with the car it's impossible for him to fix this.. somthign has gone wrong that is causing you to run very very lean..
So this is what steps I think you need to take next
1. check your fuel presure with a manual gauge..
2. If you can get another PCM for free or cheap try a PCM.
3. bring it to a dyno and have it tuned..
