painting my int. molding's
  • Thread starter Thread starter fritzPSD
  • Start date Start date Dec 30, 2006
F
fritzPSD
Utah
Dec 30, 2006
  • Dec 30, 2006
I'm thinking about painting my gray stuff black and i know that it can and has been done by others. Will it stay looking good for a long time is my concern, so if you've done it in the past let me know how it's doing.
hemi_fan
279
Ontario, Canada
Dec 30, 2006
  • Dec 30, 2006
If you use the proper paints and prep the pieces, they will last as long as you want them to. 5.0 resto sells some really good paints I hear, never tried them tho.
85GTlover
704
  • Dec 31, 2006
Yes just prep them very good..fine grit sandpaper and clean pieces well after. I used Krylon for plastic and it turned out very well in my opinion. Also 2 thin coats are better than one thick one, or more, again prep is most important. Good paint though too, I guess.
BLOWN 5.0 FOX
213
NORTH SHORE MA
Jan 1, 2007
  • Jan 1, 2007
my interior
Heres a quick shot at my interior. Custom painted console to match the car. Sanded down with a DA sander 80 then 220. Hand sanded down to 800. Use filler primer and base coat clear coat.
The pic does not do justice. As the color is b92p w/added blue pearl. Really shines up nice when the light comes in when the t-tops are off. Ooh and notice the ashtray delete? Thats epoxy filler , kind of solved the problem of it not working and looks the nuts.
GSP393
217
Orange County, Texas
Jan 1, 2007
  • Jan 1, 2007
I'm using plastic interior paint from cjpontparts. I cleaned it with PPG Acryli-clean (DX330) prior to painting.
Also I used 400 sandpaper and a red scotch bright before cleaning, you might try a gray scotch bright first and if it works well, don't bother with the red.
F
fritzPSD
Utah
Jan 1, 2007
  • Jan 1, 2007
If i sand it do i need to sand out the texture in the plastic or just enough to scuff it up a little bit so the paint will stick?
GSP393
217
Jan 2, 2007
  • Jan 2, 2007
You don't want to sand out the texture, sand it lightly, a scotch bright will take care of most of it.
85GTlover
704
  • Jan 2, 2007
Word on the sand lightly. If you sand of the texture you will notice it as the finish will be inconsistent as you will see texture in some areas none in others. The scotch bright will do the trick. You just want a good clean surface for the paint to adhere well to.
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Jan 2, 2007
Funny you guys mentioned this.. i have a friend and her and her husband just sanded down the entire dashboard and made the whole thing smooth to where you cant see any of the texture... and it looks impressive. no high or low spots.. ill have to see if i cand get her to send me a few pics.
GSP393
217
Jan 2, 2007
#10
  • Jan 2, 2007
  • #10
I'm sure it looks good, the trick is getting the finish even if you sand down into the texture.
M
How To Decode
  • Malcoll1
  • Mar 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 10, 2026
FoxChasis
F
Paint in engine bay questions
  • B0udreaux
  • Feb 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 27, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
D
sad day
  • davecobra2
  • Jul 13, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jul 22, 2026
davecobra2
D
Take a look at my rack!
  • bicknell
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2025
Willybill32
