to this day the PHB has been the most labor intensive installs i haev ever undertaken. i did it myself, with 2 ramps, 4 jackstands, and a single floor jack. by yourself its a friggen nightmare and expect to spend the entire weekend in the garage, especially if you are kinda new to massive installs. the difficulty of what has to be done is not that bad honestly, you just need to be super prepared and HAVE SOMEONE HELP!!!!! with this scenario you will get it on in less then 6 hours. with a lot of auto experience you will have it done in under 4. i cant stress enough how much ground clearance is a key player in how easy the install is. if you are doing it at home get the car as HIGH as possible.. buy 2x4s to get the jackstands higher. oh, and if yer fat with fat arms... pay someone to do it, i did well because i'm a skiiny sombish.
the MM is the best PHB on the market, personal opinion of course. you will notice a slight difference when getting just the PHB, however i will stress this point, you will notice more of an improvement once you ditch the UCAs and go true trilink (pm3l is a tad touchy for a standard road car). for some reason i have yet to equate the stock UCAs prevent the suspension from moving fully, even with LCAs, and the PHB... something is still missing.
even with that said the PHB is still worth it. my opinion, if you want it to handle well then get the phb, with LCAs, coilovers, and go ahead and get the torque arm, or do like me and get the EvM trilink (on backorder currently)
if you are planning suspension, and want it balanced, then be ready to move to the front once the rear is planted. after my trilink comes in and goes on i will be working on the front end with one large pusg (K member, A arms, solid steering shaft, tierod ends, coilovers, , self made CO isolators, and a handfull of other things).
before you move forward decide how much you are willing to sink into this project.... i have resigned to going full bore and with end up with the MM max grip package with a few slight twists. anyhow, i am having to replace my bilsteins, HR race springs, and my swaybars as they will be replaced by other things as i progress... bout 1k lost in parts with that. shrug, maaybe i'm just an addict and a freak of suspension madness.
Torinalth
