Parking Brake Help!!
  • Thread starter Thread starter blandq
  • Start date Start date Apr 24, 2004
blandq
146
Houston Texas
Apr 24, 2004
  • Apr 24, 2004
I ordered a complete replacement for my emergency brake system from handle to drum. I get out there to install it and the front cable ends (the leaded piece to termintate the wire) is oblong, way to big to fit into the new handle or even the original for that matter???
Anybody got a clue what cable I really have?
I noted, oh 8 months ago, when I removed all this stuff that the cable exited the firewall at an angle, through an angled cut-out in the firewall. There was a large black piece around the front cable. This cable does not have that?
Hack
1,945
Minneapolis
Apr 24, 2004
  • Apr 24, 2004
Sounds like they sent you the wrong thing and you should return it right away. The sooner the better.
Good luck.
65and68Stang
148
Raleigh, NC
Apr 24, 2004
  • Apr 24, 2004
Parking brake
I just went through the same thing with my '68...PO had removed the entire assembly, no handle, no cables, no lines.
I ordered a who used setup from bobsford.com in Portland. I laid everything out on the garage floor to see how it all fit together, with the help of the Ford Manual and Osborne Manual. The manuals will really give you alot of help with understanding how it all works together and what goes where.
Good luck!
Kelton
skywalker
733
Pensacola, FL
Apr 24, 2004
  • Apr 24, 2004
I just went through the EXACT same thing! My solution? Grind that piece to fit. I used a Dremel to do it. Worked perfectly.
Parking brake cable
  • 78 Mach1
  • Apr 21, 2025
1974 - 1978 Mustang II Talk & Tech Apr 30, 2025
78 Mach1
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Parking brake cable
  • Scrapla347
  • Nov 30, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 1, 2024
Scrapla347
A
95 GT parking brake instrument cluster light trouble
  • Aroenias
  • Jun 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
Mustang5L5
New to me 98 Cobra
  • bird_dog0347
  • Feb 25, 2025
2K
1996 - 2004 SN95 Mustang -General/Talk- Mar 24, 2026
FastDriver
