Part Number Thread!
Daggar
3,902
Let's use this post to provide links and part numbers for Fox body stuff. The idea came to me as I began looking through Summit for the hoses to and from the heater core. If anyone has the part numbers for these hoses (as well as the restricter), please post them here as well as information about any other Fox part and source. PLEASE DO NOT INCLUDE PRICING IN THIS THREAD. This should be a reference on where to find parts.
Thanks,
~Daggs
Heater Core Hoses
Ok... I'll start:
Heater core hoses:
Summit Racing-
GTR-63138
Brand: Goodyear Replacement Belts and Hoses
Product Line: Goodyear Molded Heater Hoses
Replacement Part: Yes
Hose End 1: 5/8 in.
Hose End 2: 5/8 in.
Hose Length (in): 12 in.
Hose Adapters Included: No
Hose Material: Rubber
Hose Finish: Black
Hose Clamps Included: No
Hose Clamp Covers Included: No
Quantity: Sold individually.
GTR-63087
Hose End 1: 3/4 in.
Hose End 2: 3/4 in.
Hose Length (in): 11 in.
Hose Finish: Black
Nope.... nothing particular. I see threads all the time from folks asking for part #s and sources for this and that. I figured I'd make a searchable thread that contained these things. The harder it is to find, the better its addition to the thread.
Note: Once you've had the chance to read this and we get the thread going, I'll be removing all posts that don't apply to the topic to keep in cleaned up. So this post and your last one will go bye bye after a while.
gas tank grommet from LRS (5.0 Resto)......LRS-9072A
dash illumination bulbs.................................# 196
fel-pro intake gaskets.................................1250, 1262, or 1262R for you big port guys
Mr. Gasket intake gaskets............................5834, 5831, 5835
Fel-pro exhaust gaskets...............................1415
FRPP one piece oil pan gasket (5.0)..............M-6710-A50
here's a good link that was posted in the corral for spark plug numbers when running boost or nitrous-good ref's for stock, GT-40, and most aluminum heads with 5.0's and 4.6's.
5.0
Stock E7 heads:
AUTOLITE
stock--stock 25 (5) [14m, .460 Reach, 5/8" Hex]
1 step colder--24 (4) [14m, .460 Reach, 5/8" Hex]
2 step colder--23 (3) [14m, .460 Reach, 5/8" Hex]
-----AR133 (3) [*recessed tip, racing plug]
-----AR132 (2) [*recessed tip, racing plug]
-----AR131 (1) [*recessed tip, racing plug]
NGK
stock--(UR45) 6945 (Heat Range - 4) [14m, .460 Reach, 5/8" Hex]
1 step colder--(UR55) 2248 (5) [14m, .460 Reach, 5/8" Hex]
2 step colder--(UR6) 7773 (6) [14m, .460 Reach, 5/8" Hex]
-----(R5673-8) 3249 (8) [*recessed tip, racing plug]
-----(R5673-9) 3442 (9) [*recessed tip, racing plug]
-----(R5673-10) 4050 (10) [*recessed tip, racing plug]
GT40 Heads:
AUTOLITE
stock--765 (Heat Range - 5) [14mm, .708 Reach, 5/8" Hex]
1 step colder--764 (4) or 104 (4) [14mm, .708 Reach, 5/8" Hex]**
2 step colder--103 (3) [14mm, .708 Reach, 5/8" Hex]**
-----AR473 (3) [*recessed tip, racing plug]
-----AR472 (2) [*recessed tip, racing plug]
**The difference between the 764 plug and the 104/103 plug is the thread. The 764 plug is a half thread whereas the 104/103 plug is a full thread. The full thread plugs are duplicates of the half thread plugs in every other aspect, they both protrude the same amount into the combustion chamber.
NGK
stock--(TR4) 3754 (Heat Range - 4) [14mm, .708 Reach, 5/8" Hex]
1 step colder--(TR55) 3951 (5) [14mm, .708 Reach, 5/8" Hex]
2 step colder--(TR6) 4177 (6) [14mm, .708 Reach, 5/8" Hex]
-----(B8EFS) 1049 (8) [*recessed tip, racing plug]
-----(B9EFS) 1085 (9) [*recessed tip, racing plug]
TFS, Edelbrock, and AFR Heads:
[14mm, 3/4" Reach, 5/8" Hex, gasket seat]
AUTOLITE
1 step colder--3924 (4) [*recommended starting point]
2 step colder--3923 (3)
-----AR3933 (3) [*recessed tip, racing plug]
-----AR3932 (2) [*recessed tip, racing plug]
-----AR3931 (1) [*recessed tip, racing plug]
NGK
1 step colder--(FR5) 3686 (5) [*recommended starting point]
2 step colder--(BKR6EY) 3696 (6)
-----(R5671A-8) 4554 (8) [*recessed tip, racing plug]
-----(R5671A-9) 5238 (9) [*recessed tip, racing plug]
-----(R5671A-10) 5820 (10) [*recessed tip, racing plug]
MOTORCRAFT
1 step colder--AWSF22C
2 step colder--AWSF32C
