Parts That Suck The Worst To Work On.
hoopty5.0
mechanicus terribilis
7,785
6,938
214
SW Houston
So I just pulled the OE 29 year old brake booster out of my coupe. Even though there really isn't a dash, it still was nothing short of miserable to remove. This got me to thinking about a list of most obnoxious parts to swap/repair on a fox.
1) Heater core. (I can't think of anything worse than this biatch.)
2) Brake booster. (Almost bad enough that you'd consider going Fred Flintstone or tossing the anchor instead)
3) ....What's next? Clutch?
Door lock actuators, unless you have small hands. And the brake booster PITA is why I keep telling people to leave it alone when they're doing big brake upgrades. Totally unnecessary.
Really? Can you explain? That would be the second fallacy I've learned about in 2 days - the other being TPS voltage is irrelevant and computer takes initial voltage a 'zero' value. Learn something new every day...
There is a simple trick to the brake booster swap. Slide the driver's seat all the way back, then prop the driver's side door open. You sit on the ground between the door and the body. Use a 3/8" drive 12" extension and a universal joint socket. You may need one of those weird semi deep Snap-On universal joint sockets the get the right clearance between the end of the bolt and the socket. You can get to all the nuts with a minimum amount of difficulty. Some tape or a disk magnet stuck in the socket helps hold the nuts to get it bolted back in place.
Broken water pump bolts sux too...
Same here... it is really difficult to get the broken bolt stubs out without damaging something else.
I have the fix for that, and it is inexpensive and lasts a very long time. The cost is: about $19 one side, $26 for both sides.
starter on an inline six fox body, especially if the car has the california emissions package. sure it looks easy at first, but you need to take the exhaust half apart to get the damn starter out. and if the california emissions package is on the car, you cant even see the damn starter.
Finding an almost dead door ringer. It is not loud enough to locate, just annoy us.
Under the dash stinks worse each year.
But a 4 eyes without factory AC is the easiest heater core change I ever did. I hope the aero mod I own has a super duty one!
Changing the tail shaft bushing without removing the T5 tranny was a pain. I had help that made a tool to do it.
