Greetings,
I've finally gotten comfortable with my MIG welder to take on the challenge of cleaning up/correcting some of the poor quality floor patches that were put on my car but I'm not sure what type or gauge steel to use.
I have just started this project and this is the first area I've looked at. The floor just in front of the rear torque boxes has been replaced with a thin gauge flat panel (tacked in above the existing panel). The remaining hole on the bottom has been sealed off with body filler. The original floor does not connect to the front of the torque box anymore - the hole is about as wide as the torque box (8" x 8"). I think I need to bridge the hole in the original floor to tie the torque box to the panel that actually carries weight.
What kind of steel should I get? What thickness (gauge)? I want to be able to bend it on a bench vice (to mimic the shape of the original floor) but still thick enough to do some good.
Suggestions?
THANKS!
Suggestions?
THANKS!
