Paxton or Vortech
  • Thread starter Thread starter blackss
  • Start date Start date Feb 6, 2006
blackss
  • Feb 6, 2006
Have a 91 gt with heads, upper/lower intakes, e cam, rods and lifters, and 30lb injectors with some other minor goodies.
I am looking at the novi 1000 kit and the V-1 SC kit.
As far as putting one on, are colder plugs going to be needed? And assuming no more than 8 lbs of boost, am I going to need a bigger fuel pump and or an FMU when I am planning to have the car professionally tuned?
M
matm347
2,056
  • Feb 6, 2006
Let's just say you are making around 300 FWHP now, with 8PSI you'll be making ~420-440 with a proper tune.
Your 30# injectors will be well over 80% duty cycle(closer to 95%) at 40 psi. You'll need to run them at around 60 psi to get them ~80% at full boost. This will require an FMU and at least an external booster pump to be safe. Possibly a high pressure in-tank could work as well.
Personally I do not like running FMUs as a good tune and larger injectors are a better solution IMO. But you would need to run 36/38#ers to get this done.
a rule of thumb is 1 step colder for every 100HP, so you should run 2 ranges colder to be on the safe side.
I would prefer the Vortech SC series, but the Novi is also a very good blower. You'll be happy with either.... I would say Procharger P1SC above either, but you did not list it as a choice.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Feb 6, 2006
  • Feb 6, 2006
KB 2.2 i know its not a choice but thats what i like!
pb_paulie_b
894
Chaptico, Maryland
Feb 6, 2006
  • Feb 6, 2006
Lots of people say Vortech buy I'm not sure if it's because they are better. Maybe because Vortech gives people alot more models to choose from. I haven't heard anything bad about paxton. I have a Vortech...PB
soontobefastfox
275
Troy, Michigan
Feb 6, 2006
  • Feb 6, 2006
procharger, yeah its not a choice but i like them because you dont tap into the oil pan and if one of them goes they both dont go if you know what I mean.
R
rflow50
172
TX
Feb 6, 2006
  • Feb 6, 2006
i have a vortech V-1 S-Trim and i am very happy with it. Paxton is very good too, but if you want to go with a Paxton go with the Novi 2000.
blackss
  • Feb 7, 2006
thanks all
I
IntenseBlue
946
  • Feb 7, 2006
Vortech SC.
Fuel Vortech Supercharger injectors
  • Dontknowchit
  • Mar 13, 2025
2K
Fox 5.0 Mustang Tech Mar 8, 2026
from6to8
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
3K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
V
pushrod 5.0 (MILD/ Torque) turbo build for an old scout II help
  • vz58
  • Apr 21, 2024
  • Other Auto Tech
2K
Other Auto Tech Jan 21, 2026
Flyboy60
F
SOLD 1993 Mustang Cobra / 114K miles / Modified / Fort Lauderdale, Florida.
  • Naja
  • Oct 4, 2023
12K
Fox Body Mustangs For Sale (1979-93) Feb 26, 2025
Naja
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
