Pedal adjustment?
Yes there is. If you feel the back of the clutch pedal arm, you will feel a plastic threaded rod. You can adjust the switch so it closes soon. I would note that the first time you bury the pedal, it will probably ratchet back down to where it is adjusted now.
Good luck.
