Pedal assembly installation
  • Thread starter Thread starter ZekeStang
  • Start date Start date Dec 19, 2004
Z
ZekeStang
12
  • Dec 19, 2004
I'm in the process of doing a 5-speed swap and i have some questions.
I'm removed the 4 bolts and the top bolt holding the stock brake pedal assembly but there's something holding the brake switch to the pedal frame, it looks like a pin, do i just remove that?
Also, how does the clutch cable install to the manual clutch/pedal assembly and fork arm? I've included pics. For ease of reference, i've numbered the pics.
Notice the nut at that end of this cable
I've taken the time to make giving instructions easier. This is the final steps and then i'll have a manual Detailed help is appreciated
Z
ZekeStang
12
  • Dec 19, 2004
bump
Asha'man
1,909
Denver
Dec 19, 2004
  • Dec 19, 2004
See the hook on the quadrant? Hook that over the end of the cable and run the cable down the channel of the quad and you're good to go.
For the brakelight switch, yes, just pull the pin. Make sure you remember the orientation of the switch so you can put it back together later.
Here's a vital word of advice - buy an aftermarket clutch quadrant and firewall adjuster and install the quad WHILE THE PEDALS ARE OUT OF THE CAR. Anyone who's ever installed a new quad with the pedals in the car can attest to how much of a PITA it is. Trust me, you'll be thankful.
Ash
V
v8only
2,378
22
49
Dec 20, 2004
  • Dec 20, 2004
Like he said, pic #1 goes to the hook on the quadrant.
Unfortunately, you've scored yourself what looks to be an adjustable cable. Since you've already got it, use it, but it could stretch, also, they don'twork well with the plastic quadrant.
read this, and will tell everything about the subject:
http://50stangs.com/techarticles/clutchcableadjustment.html
old_blue
1,783
282
124
Dec 20, 2004
  • Dec 20, 2004
They all stretch, even the stock ones, but i would agree the stock ones do seem to have a better fit and feel to them.
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
C
Drivetrain T-5 transmission issue
  • Ch3No2
  • Jul 11, 2025
Fox 5.0 Mustang Tech Jul 18, 2025
2000xp8
  • dan50
  • Jul 18, 2026
dan50
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
