Pedistal Mount Roller rocker saddle cracked?
Flavadave4
1,044
21
49
Utica, NY
So I notice that I have a crack in one of the saddles that goes under the rocker arm, I take them all off and notice 2 of them are cracked. Can I get new saddles somewhere or am i stuck getting a whole new set of roller rockers?
BTW these are 1.6 Ford SVO pedistal mount.
Thanks for any help you can give!
You'll probably end up having to replace the damaged rockers, but I'm not 100% sure you can't get parts for them. I think Crane makes FRPP's rockers, so you could just order some individual replacement rocker arms from Summitracing or something if worst comes to worst.
The arms themself are fine, just the little part they sit down on. I noticed Summit sells the rockers in sets of 2 for $58......Maybe the route i will have to go in the morning!
good catch - failed valve trains can get expensive.........
All i could picture is one breaking and jamming a valve spring and pieces and parts rattling around in my valve cover!
Tmoss- getting her ready to go to the dyno, electric fan, 70mm Pro-m maf, 65mm TB and EGR. Going to try and get the most out of this Tmoss intake with Thumper heads and TFS1. Wish me luck!
