  • 1994 - 1995 Specific Tech
PELASE HELP FAST!!what comes with a kb??
  • Thread starter Thread starter DDSTANG94
  • Start date Start date Aug 31, 2007
DDSTANG94
465
FRASER, MICHIGAN
Aug 31, 2007
  • Aug 31, 2007
I found a kenne bell on eBay i want to get but it is just the supercharger and nothing else..what else do i need to get it to work, what belt, or belt tensioners, what does the kit come with new...i no i need new injectors
go-stang5.0
2,244
Glenview,Il
Aug 31, 2007
  • Aug 31, 2007
try calling kenne bell There are a few guys on here that have/had them but I don't so I couldent say more to you than that.
toyman
1,944
54
79
Vernon BC
Sep 1, 2007
  • Sep 1, 2007
In addition to the supercharger (which includes the supercharger, inlet manifold,discharge manifold, supercharger shaft, housing and pulley) here's the list.
Fuel system booster
11/32" x 16" Line (to PVC)
11/32" x 11" Line and coupler(to vacuum tree)
Vacuum line assembly
New drive belt (same size as stock)
Front Supercharger support bracket, idler & hardware
Manifold bolts
Lower intake manifold gasket
EGR plate gasket
TB gasket & bolts
Fuel sysytem Booster lines (2) and Safety clips
Thermostat Housing, Gasket and bolts
Radiator Hose sleeve, clamps (2) & loom clamp
Coil bracket
Coil wire
T-handle wrench
That pretty well sums it up. Be aware that if you have a GT40 intake the standard KB will not fit. Since you have 24 lb injectors you may not need the Fuel system booster (it's designed to work with the stock 19 lb injectors. At WOT the booster shuts off the return line flow which increases fuel flow to the injectors). Confirm with KB.
toyman
1,944
54
79
Vernon BC
Sep 1, 2007
  • Sep 1, 2007
Is this the one? Item 300145204578. I'm wondering why it has been opened. You might want to again check with KB as new gaskets may be required.
DDSTANG94
465
FRASER, MICHIGAN
Sep 1, 2007
  • Sep 1, 2007
Fuel system booster
Manifold bolts
EGR plate gasket
TB gasket & bolts
Coil bracket
Coil wire
T-handle wrench
Thanks man!
DDSTANG94
465
FRASER, MICHIGAN
Sep 1, 2007
  • Sep 1, 2007
Ya u got it, that's the one, but i dont think I will be biding on it because it is not complete, and u got me thinking about it being opened up, Who knows what, or who was in there....Thanks again for your response
toyman
1,944
54
79
Vernon BC
Sep 1, 2007
  • Sep 1, 2007
Like you I was watching a couple of KB auctions before I purchased mine from KB. At the time they ultimately sold for about $400 less than new which to me didn't make sense considering you didn't know what else you might need, what the additional costs could add up to and have an older unit with no warranty.
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
A
Procharger install/prep questions
  • ahratrew
  • Nov 22, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 26, 2025
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
What's it Worth? 2000 GT
  • Mustang5L5
  • May 8, 2026
  • What is it Worth?!?!?
What is it Worth?!?!? Jun 13, 2026
KRUISR
M
Broken lower intake bolts
  • Mike3
  • Aug 11, 2025
1994 - 1995 Specific Tech Sep 2, 2025
revhead347
