Is anyone running subframe connectors with side-exhaust? I was thinking about using this because I really want side-exhaust and subframe connectors https://www.drgas.net/category.php?cid=49&catid=1
those are nice but really expensive...great idea though
i hope i won't need to buy those when i get around to installing my side exhaust. I have full length kenny brown subframes and would hate to have to either buy those or ditch the subframes.
Well.. My setup is kind of unique because it's custom after the x.. I had the exhaust shop tuck it super tight to the body, so subs will be a challenge..
I am a welder by trade, so the fab work will be a breeze..
My plan is to buy whatever sub's I plan to run (probably MM) because I believe they need to tie into my future panhard bar? Anyhow, I'll just go about installing them as you would, but I'll have to notch them out around the pipe and then brace them in.. I will probably use a fairly thick flatbar to try to hold some rigidity at the cutout, then make some fore/aft ribs that are cut around the pipe.. I'm not sure if you can picture this the way it is in my mind, lol.. This should be one of my summer projects, but I don't have a welder at my house..
I rem a few years back that Steeda or someone like that had some subframe connectors that were made to clear side exhaust set-ups. I didn't have the $$ back then though. I'd like to get a subframe set-up though...
