You first need to compare the "@ .050" duration figures. The cam you now have is more like an RV/ factory Hi-po cam. Those duration figures are misleading. Do you want more cam, or less cam? Or in other words, do you want the engine to put out more power, farther up the rpm scale, or move the powerband lower down the scale ? The 280/.512 lift cam sounds like Comp Cams 280H, which is a lot hotter cam than what you have now, which will in effect move the power output farther up the rpm scale. The @.050 duration for this cam is 230* vs the cam you have now, which is likely in the neighborhood of a 214/224 @.050 I know this sounds wrong but that's what the "Advertised" figures (which is the 290/300 on your cam) vs the 280* for the Comp 280H translates to in the more important @.050 figure is. The duration and overlap affects output far more than the lift figures do. Overlap is the time in which both the intake and exhaust valves are open at the same time between top of the exhaust stroke and the begining of the intake stroke. Overlap is also controlled by the lobe separation angle. A wider angle results in less overlap, a narrower one creates more overlap. Overlap serves to create a scavenging effect in the upper rpms, flushing more exhaust out of the cylinder chamber. It also affects idle quality (more ovelap creates the "rumpity-rump" idle associated with Hi-po cams) I hope this helps you in deciding what cam you really want, you weren't real clear in what you meant by your thinking your cam wasn't really tailored to your needs.
