  • SN95 4.6L Mustang Tech
Performance Questions
  • Thread starter Thread starter 03gtstangguy
  • Start date Start date Jul 25, 2004
03gtstangguy
36
  • Jul 25, 2004
I have three questions: Dollar for Dollar is a chip as good an investment as any? How much can I expect, reasonably, to pay someone to install rearend gears? Speaking of gears, 3.55's or 3.73's? Thanks for all the help guys!
T
tangerine
555
millen, ga
Jul 25, 2004
  • Jul 25, 2004
I would wait on a chip. You will see little hp gains off of this. Wait till you get a lot of mods for this. The gears most people usually charge about 250-300 for gears to be installed but this doesn't include the cost of the gears.
twogts4us
4,188
12
79
Dunedin, FL
Jul 25, 2004
  • Jul 25, 2004
Yep, I'd wait on a chip til you have enough mods to warrant one. I was talked into one and made the mistake of listening(!), but, with my mods, I should have just gone with a speedcal. With the money saved get a timing adjuster and bump up to 14 degrees. (stock is 10) You'll need to run premium fuel with the additional advance, but this will get you near what a chip would do for an other basically stock GT...about 3-4 HP.
I paid $420 for the gears, install kit, (Royal Purple) gear oil, labor...everything.
Gear selection seems to come down to 3.73 or 4.10. 3.73 make a big difference, 4.10 make a huge difference. Insist on FRPP gears. If you have an automatic, definately get 4.10s.
Speaking of automatics, if this is what you have, you'll need a chip or handheld programmer (like a Diablo Predator or SCT MAX MicroTuner) rather than the speedcal because you'll need the shift points changed because of the new gears. The handheld programmers will also be able to correct the speedometer.
sjrtx
151
Houston-NW side
Jul 25, 2004
  • Jul 25, 2004
for me-it was an awesome investment. mind you, a stock tune wouldnt have changed anything. infact, id tried a SCT chip with a stock tune and it didnt increase horsepower in the least bit. The only advantage youd get from it assuming your car was running in the right a/f(not running too rich or lean), would be calibrating the speedo for gears, turning off the traction control permantly, and bumping up the timing.
dont buy a chip til youve got quite a bit of mods, then stick it on a dyno with wideband so you can see what you a/f is at. In my case, i was running real rich for some reason. I paid 500 for a dyno tune, and we only managed to pick up a few horsepower. Then i took it to another shop(strictly performance), and we did a baseline with the chip(234 peak hp) and without (234). Then we made some changes, got the a/f where the car liked it the best, and the peak picked up to 247rwhp in 99 degree heat-with lots of humidity. But-the best part was around 3800rpm-the car picked up almost 40lbs of torque. After advancing the timing quite a bit, we even took out a couple degrees, because the 2 degrees we added didnt make hardly any difference. Once i get pullies, and my Fipk-hopefully ill be in the 250+ range.
03gtstangguy
36
  • Jul 25, 2004
Ok, thanks guys. My Stang is a 5-speed, so what mods would you go for first? I assume gears are near the top of the list. What else?
DBMSTNG
I fantasize about it being BIG!
2,120
not quite here
Jul 25, 2004
  • Jul 25, 2004
mid pipe and pullies.
twogts4us
4,188
12
79
Dunedin, FL
Jul 25, 2004
  • Jul 25, 2004
gears, cat back, midpipe, long tube headers, shifter, plenum & TB, upper and lower control arms, lower springs, shocks, struts, C/C plates, sub frame connectors...OK, are we out of money yet?!?! ;-)
03gtstangguy
36
  • Jul 25, 2004
LOL Yeah, way out of money! What is TB and C/C plates? Does the intake spacer live up to its billing? I think I will look into gears and underdrive pulleys next...then the chip.
Go HoTO!
602
Mountaintop, PA
Jul 26, 2004
  • Jul 26, 2004
As already stated, wait on the chip. But, a programmer is not a bad idea due to the flexibility they have to grow with your car.
Programmer Cost - $400 (give or take)
Speed Cal - $100
Timing Adjuster - $150
Total - $250
So, you have to ask yourself, is it worth it to spend $150 to have a tool that can give you diagnostic codes and has flexibility to grow with you?
Timing Adjusters are really great if you plan on drag racing (legal type) type a lot because you can adjust your timing as much or as little as you want and even for racing fuel.
Other than that, if I could do it all over again, these are the mods I would do and in this order starting out. Note, not all are for performance:
1 - Shifter (< $200)
2 - Gears ($500 - $600 total) (feels like 40 hp with 4.10's)
3 - Rims! ($400 - $800 for most sets)
4 - Exhaust (catback and mid pipe) (about $800) (10 - 20 hp)
5 - Pullies ($150 + $50 to install) (5 - 8 hp)
6 - TB and Plenum combo (around $400) (10 hp)
Defleshed
Satanic Mechanic
Nov 30, 2003
10,569
In Torment, In Hell
Jul 26, 2004
#10
  • Jul 26, 2004
  • #10
vortech and 4.10s dude. You'll be a rocket.
V
VincentL
#11
  • Jul 30, 2004
  • #11
What would a chip or the predator net me with my setup?
2k GT
3.73 gears
Underdrive pulleys
Bassani catted X-pie
Bassani cat-back
70mm TB
K&N FIPK
Aluminum driveshaft
Steeda Tri-ax
Intake plenum is next on the list of coming mods... yeah I know, very little gain, but hell, its the only intake mod left
Car did 250rwhp a year ago as it is on 87 gas. Is a chip gonna give me enough to warrant going to 93 octane?
Thanks!
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
M
93 5.0 Microsquirt with Stage 3 trickflow tuning issues
  • marxpreston11
  • Jun 22, 2026
  • Digital Self-tuning Forum
  • 2 3 4
2K
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
Drivetrain How much resistance, if any at all, is normal on a new 1st gear and synchro on a WC T5 transmission?
  • sleep-e
  • Jan 21, 2026
Fox 5.0 Mustang Tech Jan 22, 2026
sleep-e
R
Kenne Bell Supporting Mods for 2002 GT?
  • Rembrant
  • Mar 25, 2025
SN95 4.6L Mustang Tech Mar 25, 2025
