Performance Upgrades
Sketchy_GT
194
56
48
i have a 1988 LX that i recently purchased and the 5.0 has been rebuilt recently but everything was put back to factory specs. i want to slowly start upgrading things making the car faster, as money permits. it has an aluminum intake, a/c delete, no cats into flowmaster 40's. any suggestions starting with the smaller power adders would be great. Thanks
And the people here like pics for some reason, I don't, makes me jealous.
What kind of power adders, nitrous, turbo, blower sticking thru the hood(my personal favorite) or just heads cam intake. Left yourself for the old 'stick a leaf blower on it' rag (another personal fav)
All new upgraded brakes? Or new semi metallic pads on stock fox rotors with drums in the back? :-)
Since it's a fresh rebuild-I'd upgrade the suspension and save for a blower
Far too many people put a dab of this and a dollop of that, and then wonder why the car doesn't run worth beans. Then they think off the shelf computer chips will fix their mismatched parts problem. It won't
You have to have a plan for what kind of performance you want: Hot street. Street/Strip, Pure strip, Autocross or Road course. Each one requires a different strategy and a different set of components.. Mismatch the components and you’ll have a car that falls flat on its face when you demand performance.
Everyone thinks HP! HP! HP! and thinks that peak HP is what they need. Peak HP is great for a drag strip car when it has the proper gears and tires to get the car up into the high RPM range where it develops that high peak HP near the finish line. On a street car, that strategy will have Honda Accords outrunning you, because you will never get the engine RPMs high enough without running over everything in your path.
Here’ the strategy: Always remember that there are some tradeoffs in any engine combination. Most of us don’t have enough money to “have it all” as if it was possible by some masterful combination of parts and tuning.
The following recommendations are for 5 Speed Manual transmission cars without NO2 or pressurized induction, stock short block.
1.) Hot street: Broad flat torque curve, high velocity airflow in the intake and heads for best throttle response. Gears suitable for reasonable gas mileage and long road trips without excessive engine RPMs. Stand on the gas pedal from a rolling start to squeeze into that gap in traffic in front of you, and it jumps quick and hard to get you there. Max RPM’s are 5200-5500 RPM for best power. Lopey cams may sound cool, but run poorly in a low RPM street environment.
Use stock cam, stock, GT40 or mildly ported stock heads, Cobra or Explorer/GT40 intake, advanced timing, stock 19 lb injectors, stock fuel pump. Use some good 1.6 or 1.7 ratio roller rockers for extra punch. Use a King Cobra clutch, with stock iron or steel billet flywheel. MAF cars can use a 65 MM TB from the Explorer intake manifold and a 70MM MAF from a 94-95 Mustang. Drive train: 3:55 gears with soft tread compound tires. Use some Ford Racing unequal length headers, stock 2 1/4” cat pipe and some mufflers that don’t drone or get too much attention from the law enforcement or neighbors. The stock computer will handle all this with no problems and doesn’t need any help in 90% of the cases. No skinny or grossly undersize tires for the front: remember you still have to stop quickly in traffic. Make sure all the rubber bushings in the front and rear suspensions are in first class shape. Leave the emissions equipment intact and working. Removing or disabling it won’t get you any more HP or performance. Do not convert to carb or remove A/C: either one will reduce the resale value. Carb conversions cannot be titled for street use or get tags in some places. They definitely won’t pass smog inspections.
Street/strip: A little more slope to the torque curve with a gently sloping peak. Use slightly larger port volumes on intake and heads for more peak HP. Uses 3.55 or 3.73 gears to get the RPM’s up into a higher range quicker. Be prepared to sacrifice some low RPM throttle response in exchange for high RPM power. This by necessity will be a Mass Air or Mass Air conversion on 86-88 5.0 Mustangs, since stock speed density will not run well with the changes in engine airflow. Don’t get too crazy on any one engine part since you still have to drive the car on the street, and a mismatch can make street driving miserable.
Use stock or mild aftermarket cam, Ported GT 40, or 165-180 CC port volume aftermarket aluminum heads. Use a Trick Flow, Edelbrock Performer or equal intake manifold. Take a 73 MM aftermarket MAF calibrated for 24 lb injectors, and 24 lb injectors, 155 LPH fuel pump, Kirban adjustable fuel pressure regulator. Be prepared to shell out some $$$ for a custom burned chip using data gathered from a dyno run. Mass market chips will not get the job done. Use some Ford Racing unequal length headers, aftermarket 2 1/2” cat pipe and some mufflers that don’t drone or get too much attention from the law enforcement or neighbors. Drivetrain: expect the stock T5 to fail, so save your money for a super duty 5 speed trans. Tremec 3550, TKO 500 & TKO 600 are the best choices. Different gears in a stock T5 case work for some, but there is only so much power you can pass through a T5 in race mode before it breaks, even with stronger gears. Next are the Chassis mods: full length subframe connectors, different springs, different shocks, aftermarket lower and upper control arms with rubber or urethane bushings. Buy all the parts from someplace like Maximum Motorsports, Griggs or Steeda as a kit so that you know that all the parts fit and don’t argue with each other. Carry spare tires and wheels for the drag strip: skinnys for the front and drag radials for the rear. No skinnys for street driving! Over 85% of the breaking power is generated by the front tires, so skinnys won’t do the job in a panic stop situation. Disconnect the front anti-roll bar at the strip; reconnect it before you drive home. Leave the emissions equipment intact and working. Removing or disabling it won’t get you any more HP or performance. Do not convert to carb or remove A/C: either one will reduce the resale value. Carb conversions cannot be titled for street use or get tags in some places. They definitely won’t pass smog inspections.
Strip only: High RPM, High flow heads (185-215 CC port volume), wild cam, high flow intake manifold, 70 MM or larger TB, 80 MM or lager MAF, strip everything out of the car that doesn’t make it go faster. Carbs are OK if that’s what you want, but remember that as the temp/humidity/ barometric pressure/altitude changes, you have to re-jet and readjust the carb. EFI eliminates most of that with its built in compensation or you can tune of the fly with a high end Motes or Tweecer system combined with a wide band air/fuel ratio meter. Use custom headers, dumps and minimal mufflers. How fast you can go on 5 liters is a function of the skill level of the driver/mechanic and the size of your wallet.
TRAILER the car to the race track since it won’t be legal to drive it on the street. Drag slicks in the rear, skinnys up front, use 3.73 or bigger gears (4.xx) in the rear axle. Since you won’t be driving on long trips, the big gears with work with the high RPM power curve to get the best results. Drivetrain: TKO 500 & TKO 600 are the best choices. Different gears in a stock T5 case work for some, but there is only so much power you can pass through a T5 in race mode before it breaks, even with stronger gears. Next are the Chassis mods: full length subframe connectors, different springs, different shocks, aftermarket lower and upper control arms with rubber or urethane bushings. Buy all the parts from someplace like Maximum Motorsports, Griggs or Steeda as a kit so that you know that all the parts fit and don’t argue with each other. Remove the front sway bar, put an airbag in the rear spring of the side that spins the tire the most. Plan on a roll cage if you are truly serious about going fast: most strips will require it once you get to a certain ET range.
Autocross is a combination of Hot street engine and street strip chassis prep. The engine must accelerate quickly from low RPM and needs a broad, flat torque curve. Next are the Chassis mods: full length subframe connectors, different springs, different shocks, aftermarket lower and upper control arms with rubber or urethane bushings. Buy all the parts from someplace like Maximum Motorsports, Griggs or Steeda as a kit so that you know that all the parts fit and don’t argue with each other. Most of the time you’ll never hit third gear, so some 3.73 or bigger gears (4.xx) may help a lot. You’ll have to spend some more money on brakes since it kills brakes quickly. Rear disks, larger rotors up front, stainless steel brake lines, different brake pads. A 87-88 T Bird Turbo Coupe or SN 95 rear axle will be your best bet. Autocross will severely strain 1st & 2nd gears, so your T5 may take a premature dump. Save your money for a super duty 5 speed trans. Tremec 3550, TKO 500 & TKO 600 are the best choices.
All out road race is the most difficult of all: an engine that will run at high rpm hour after hour and never fail, yet pull hard out of the hairpin turns that will require a lot of torque at lower RPMs. In my opinion, guys that can successfully build a winning road race engine are the cream of the crop. Top this off with a chassis built for strip only duty, but with changes to the settings of springs, tires, roll bars brakes and shocks. It’s a whole other world of racing.
You’ll have to spend lots more money on brakes since it kills brakes quickly. Rear disks, larger rotors up front, stainless steel brake lines, different brake pads. Air ducting to cool the brake rotors will be a must. The brake rotors of cars on a high speed road course glow red after several hard laps of racing. Drivetrain: TKO 500 & TKO 600, and T56 close ratio are the best transmission choices.
Depending on where you live, I would put the a/c back on first! There is little to no benefit not having a/c.
To make it faster there are thousands of things/combination that you can do.
Personally if I had a stockish base like yours. I would find out the injector/maf/tb sizes, gears, auto or manual first, control arms (upper/lower), fuel pump and plan from there.
From my personal experience, I would start here
Install sub frame connectors and torque box reinforcements
Then search for a used/new supercharger kit with fuel components and tune....
Then drive it
Some would argue go for the an HCI first install then supercharger, but you can achieve almost block splitting power in stockish form with support fuel. You can squeak out more with the HCI first but the end result will be the same with less money.
My .02
All new upgraded brakes? Or new semi metallic pads on stock fox rotors with drums in the back? :)
Upgrade.
Consider it an investment into your car seeing that your average modern minivan can probably outbrake a stock fox these days. Last thing you want is to crunch the front end of your car up when Mama Bean throws on the binders of her Sienna at the last second to pull into a Starbucks.
Upgrade.
I completely agree,that's why I was asking if he had upgraded or just replaced stock parts
street/strip all new brakes
Great post. :) For Hot Street, especially with an AOD (automatic) transmission, I would recommend the stock HO intake manifold, with the lower intake ported over the Explorer/GT40 intake manifold setup. The stock intake has a broader torque range and has more low-end torque than the explorer intake, due to it's design. The oval runners are smaller than the Explorer runners, but they flow more than enough for the stock heads and provide better air velocity. The only restriction in the stock intake is the front two lower intake runners due the sharp turns. I've just enlarged the ports to match more closely to the stock head intake ports and grinded-down the sharp 90 degree turns as much as I could without thinning the cast too much. It is easier to spin the rear tires off the line in my 91' gt vert with the stock modified intake w/ the stock 60mm throttlebody and 70mm sn-95 maf, then my old 93' gt vert with the explorer intake w/ 65mm throttlebody and 75mm pro-M maf. Both cars have identical mods except for the intake setup. My 91' even still has the heavy duty fan clutch, while my 93' had the taurus electric fan.
Reactions: Davedacarpainter
I had a 93 notch that ran 12.4 on street tires. Sub frames is the first thing to put on before anything crazy. I started with just the stick block, e cam and added bolt ons.. Intake, injectors, heads, headers, throttle body, rockers 373 gears. Then moved on to driveshaft, transmisdion, fiberglass hood. I read someone said put the ac back in.. their right doesn't really make a big difference.
All it basically does is add a bit of weight. That little plug that hooks up to the a/c compressor is actually a sensor that disengages the clutch during heavy acceleration (flooring it), so it does not rob any power.
Subframe connectors:nice:. Very first upgrade.
Then brakes.
Then bushings. Springs, good shocks.
Then supercharge the **** out of it. That stock block will take 450hp. Tweak the crap out of it to 450. That's a good and fun number that will leave you giggling.
Some people make even 500hp + on the stock block.. It all depends how high you spin the motor. Keep it under 6k and It will live a little longer.. :nice:
