PI ENGINE SWAP HELP!
able2flyy
33
Hey guys i bought a 96 gt shell and just got and engine and tranny from a 2000 gt yesterday....my questions are...
1. Should i use the new map sensors or the ones that should be on the 96(i have the 96 map sensors also)
2. Where should i mount the coil packs
p.s i allready swapped the fuel rails, wiring harness and put on the second temp sensor....any info or pictures would be great!!!
I would use the 96 Gt Map. On the coil packs. You should be able to swap everything over to the same spots that they are on the 96-98 GT's. You can reuse the brakets, etc. If you have any questions feel free to pm me anytime. Good Luck with the project!
i dont know much about the non-pi engines but i heard that there is a spot on the timing cover where the coil packs go and the 2000 engine doesnt have it, so what do i have to do?
