  • SN95 4.6L Mustang Tech
pi head info needed
  • Thread starter Thread starter stanford20
  • Start date Start date Jan 1, 2005
stanford20
55
elkmont
Jan 1, 2005
  • Jan 1, 2005
i can get a set of pi heads and windsor valve covers for 250 bucks. the heads have bout 50k on them, they are partial ported and he said may need a valve job. is it worth it. can i do thevalve job myself, are they hard to install, and will i have a good horsepower gain and will i need a computer upgrade?
MyEarsHurt
918
  • Jan 1, 2005
Am I missing something....these parts are not for your 04 GT right? Cause that has pi heads on it from the factory.
CanadaStang
2,093
Mb
Jan 1, 2005
  • Jan 1, 2005
What are you wanting to put them on?
Pughman
295
in a galaxy far far away"MISSOURI"
Jan 1, 2005
  • Jan 1, 2005
I
Iniquity
41
  • Jan 1, 2005
only point i can see is if you make those heads your project with some aftermarket cams/springs and a decent port job.
CanadaStang - You suck
stanford20
55
elkmont
Jan 1, 2005
  • Jan 1, 2005
i dont quite see what you are sayin to say man
I
Iniquity
41
  • Jan 1, 2005
You ALREADY have PI heads. Why would you switch them out with OLDER PI heads?
Stang|ess
seeking cyber partner(s)
Oct 18, 2003
941
Hawaii
Jan 1, 2005
  • Jan 1, 2005
1996-1998 Mustangs had the ****ty heads (NPI heads)
1999-2004 Mustangs have PI heads.
You plan on swaping your new 2004 PI heads for older (50,000 miles) heads? I just think you're confused.
TweekedGT
1,274
Alberta
Jan 1, 2005
  • Jan 1, 2005
Someone had too much sauce last night!!!
stanford20
55
elkmont
Jan 1, 2005
#10
  • Jan 1, 2005
  • #10
actually i did have too much sauce it was a good nite. i had no idea pi heads was factory heads i thought they were some aftermarket heads or something.
since i aint getting the heads anymore i was thinkin bout c&l intake pipe and maf and plenum what you guys think
40th GT
916
Lawrenceville, GA
Jan 1, 2005
#11
  • Jan 1, 2005
  • #11
PI=Performance Improved.
Don't waste your money on that intake pipe and the MAF. The pipe won't give you much gains except for maybe 1hp if you're lucky. It's just mainly for looks. You won't need a bigger MAF until you hit 350+ RWHP. The plenum will give you about 6-8 RWHP when combined with a bigger throttle body and it'll cost about $400.
CanadaStang
2,093
Mb
Jan 1, 2005
#12
  • Jan 1, 2005
  • #12
Blev
1,295
So. Cal. V-Town
Jan 2, 2005
#13
  • Jan 2, 2005
  • #13
if the heads are only 250 bucks, I would get them and send them off to be worked over and a good P&P. Then put some agresive cams, better springs, valve guides, valves, lash adjusters and followers. You'll have a really good gain over your stock PI heads and cams.
TweekedGT
1,274
Alberta
Jan 2, 2005
#14
  • Jan 2, 2005
  • #14
Sorry i just had to have a little fun with you there. Only us 96-98 suckers need to worry about the PI stuff. You already have the goods. If you can get them for $250 why not. Send them to Total Engine Airflow or a local shop that you know of and get them ported and polished real good. While your at it get VT stage 2 cams and new springs and you will probably gain at least 50-60 horse.
stanford20
55
elkmont
Jan 2, 2005
#15
  • Jan 2, 2005
  • #15
not tto bad of an idea and a nice hp gain mighyt end up doing that how much would all that cost im guessing around 500 600 bucks after i buy the heads
TweekedGT
1,274
Alberta
Jan 2, 2005
#16
  • Jan 2, 2005
  • #16
It will be more like $1500 for the full meal deal. To do a good port and polish job my guess would be about $500, VT Stage 2 Cams I believe are around $599 for both and the new springs that would be required for the cams would be another $400. Won't be cheap but will add some good snap. This is if you can do all the work yourself of course. You'd have one bad N/A stang.
O
o0akoni0o
175
Fremont, CA
Jan 2, 2005
#17
  • Jan 2, 2005
  • #17
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
V6 to V8 Swap info
  • 02_2v_Curtis
  • Jan 11, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 7, 2026
2v_johnny
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
