Ok guys i have a set of 2000 PI heads with a set of 2002 PI cams will these cams go into the heads without problems? Also how do you tell the difference between the left and right side cams? Please help me with these.
shoulddn't be a problem at all putting the cams in those heads. The difference between the cams is the length. I want to say the left bank has the longer cam, but i may be wrong
I take it you have the cam gears for the 02 cams? They will fit no problem. The cams should have some numbers encraved in them. Post those numbers and I can possibly tell you from that which is which.
ok guys i just recieved my heads and cams and the heads have this number on them RF-XL3E-6090-C20D i was told that there 2000 GT heads making them windsor heads but my windsor valve covers I bought dont fit. The only numbers I could find on the cams are.....one cam has these 2 sets of numbers C2 and R2 and the other cam only has 04 on it. Please help guys.
How many valve cover bolt holes are on top of the heads? Off the top of my head, they are 13 per head for windsor. You are probably better off with romeo heads anyway, the lil windsor valve cover gromet bolts are $4 a pop. You can easily tell what cam goes where when you get your stock stuff off, just match the lobes up. Also if the windsor valve covers dont work, then your stock 98 ones will if the heads you bought were romeo.
Well everything worked out fine I found out which cam goes to which side and the heads are windsor heads so i got the covers to fit fine...I was being stupid and not noticing the littlest things.
