  • 1994 - 1995 Specific Tech
Pic request/progess + fiveoho
  • Thread starter Thread starter cbarr300
  • Start date Start date Mar 7, 2007
C
cbarr300
746
goose creek, SC
Mar 7, 2007
  • Mar 7, 2007
Can someone post a pic up showing how the clutch cable is routed around longtubes? I'm trying to get the cable going and can't exactly remember how it goes.
got the engine/trans put back in...ended up putting the motor mounts on the wrong side cuz I'm brilliant like that. Tomorrow I'm gonna finish connecting everything and putting the upper intake on.
Fiveoho: about that teflon RMS....it wasn't really hard to get it on. The Fel-pro one comes with a plastic sleeve that makes it 10 times easier to put the seal on. After that just evenly tap it til it's flush with the block (I used the old seal to help out)
I can't speak for the performance of the seal yet, but it sure is on there tight.
:SNSign:
fiveoho
1,958
TN
Mar 7, 2007
  • Mar 7, 2007
i greatly appreciate the info. i may go teflon. good tight seal is what im after, sounds like that is what you got.
thanks again!
C
cbarr300
746
goose creek, SC
Mar 7, 2007
  • Mar 7, 2007
Yeah, I tried putting it on and couldn't get it on no matter how hard I tried....then I remembered a plastic sleeve that came with the RMS...slipped that over the crank and it went right now.
also, when removing your old one (if you haven't already done it) I'd drill 2 sheet metal screws in there and pry it out with a claw hammer.
Blackened302
1,439
South TX
Mar 8, 2007
  • Mar 8, 2007
i have the Maximum Motorsports OE universal cable (only $60 and great quality) and it's intentionally longer for header clearance--might wanna give that a shot.
fiveoho
1,958
TN
Mar 8, 2007
  • Mar 8, 2007
sounds like the plastic sleeve is important...do all RMS come with it? does autozone, advance or o'reily's have that same RMS you got? and the pan does -not- have to be dropped, right?
thanks for the top with the screws.
and about the clutch cable, +1 for MM. i have that cable too but a FWA is a must with it.
C
cbarr300
746
goose creek, SC
Mar 8, 2007
  • Mar 8, 2007
I couldn't tell you if other RMS's come with it. I got my felpro off summit racing for right around 40.
Stripped Crank threads and cracked Crank Shaft Ring at end (what is it called?)
  • 69machmike
  • Nov 13, 2024
1965 - 1973 Classic Mustangs -General/Talk- Nov 19, 2024
89ripper
M
  • mnky99
  • Sep 5, 2025
mnky99
M
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
7K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Fuel Fuel Pump Rewire, New Fuel Lines, and Installation of New Fuel Pump Hanger with AN6 Connections
  • AeroCoupe
  • Mar 12, 2023
14K
Fox 5.0 Mustang Tech Apr 16, 2023
AeroCoupe
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
