I have recently bought an A-pillar gauge pod and a 5" monster tach with shift light and was wondering if I could see some pics of gauges in sn95's for some ideas for placement of the tach. Thanks!
The tach would probably have to go towards the middle of the dash, since I couldn't imagin seein out the window with it on the left next to the guages.....but I dunno...
The oil pressure sender is huge. I mounted mine on the passenger side fender when the car was N/A. Now it sits under the blower. Autometer sells a braided line that screws into the block and then you can remote locate the sender almost anywhere you want.
I tied all my electrical connectors into the right side harness that attaches to the factory cluster. If you decide to go electric then you can send me a PM and I can try to walk you through it.
I had a couple open spots on my GT40 lower for a 3/8 NPT fitting, which the Water temp guage comes with. I just screwed it into one of those. I spliced all my wiring into the wiring for the clock, since I did a clock pod.
