PING, RING, PONG, TING!!!! HELP!!!!!!!!!!!!!
rapidsft
37
San Jose
95Mustang GT 5-speed, 123,000 miles
HELP ME!!!!
IT WON'T STOP PINGING WITH 87 OCTANE AT 3 DEGREES TIMING, ARRRHHHHAAAA!!!! I'M GOING CRAZY!!!
1) only pings when it's warm
2)has timing set at 3degrees initial
3)completely stock
4)will ping at ANY RPM once it's warm
5)91 OCTANE helps, but it'll still PING
This is my other car, I also have a 94, which runs real well, however; I had to reduce the timing, since it also pings, just not as bad.
have you pulled codes? cleaned the MAF? checked fuel pressure? i would not run at 3* base timing. are you sure the balancer did not spin?
good luck.
Clean the Mass Air meter. How fresh is the tune up? Oh, run nothing but super unleaded in it. My old 95 had same problem at 4500-5000 rpm and after i cleaned the Mass Air Meter all problems solved. This was with stock timing of 10degrees.
