03gtdrkpny
That's the issue around here, everyone tells you to do something (get rid of them, drop that beast, etc.) but rarely are the consequences mentioned.
There are always consequences to not preparing properly and doing the job hastily.That's the issue around here, everyone tells you to do something (get rid of them, drop that beast, etc.) but rarely are the consequences mentioned.
I was not going to say anything but since you raised the topic, what kind of results can be expected by doing the job in the dark with a flashlight for light? Was a heat gun used to soften the adhesive as is always recommended? I did not see any mention of a heat gun.
You are getting free advice and if you are going to do the job and you are not a professional mechanic then you need to do some planning before you start the work and have the correct tools available.
Not directed towards you I just used the work you performed as a counterpoint example to the point that was made in what I quoted.Dude Trout I hope everything you said was not directed at me seeing as I didn't even " raise the topic". If it was, then before you bash what I did and quote something that you thought was me, you should look at who said it. If you would have read, not only is the night the only time I have to work on my car but I did do the job properly and used a large spot light, not a flash light. I used a heat gun also. Sometimes **** happens.
YOU are getting free advice and if YOU are going to do the job and YOU are not a professional mechanic then you need to do some planning before you start the work and have the correct tools available.
Yes I did use the fishing line, with a heat gun. I did it about for about 2 inches in and then began just slowly pulling it with my hand. I searched alot on this topic. lol. I found the thread where the guy said fishing line and even posted in there. I did pull the one side slightly faster than the other but honestly even if i took like 2 hours on it I still think it would have taken the paint off. I did take my time. I duno maybe my door had been repainted before too. **** it was titled in Canada it could have submerged in water for all I know and wouldn't necessarily show up on the carfax.
