piston 2 valve clearance?? heads shaved .030 ??
i have a 2000 short block has stock 2000 gt rods and pistons with a cobra 8 bolt crank, pi heads shaved .030 with comp cams xe278 with 242 246 duration and 550 lift with the comp cams matched beehive valve springs, cometic head gaskets, bullitt intake with the complete installation kit including an anderson powerpipe the kit also includes the alternator, radiator hoses, and accelerator cables, wiring harness is complete untouched no cut wires and computer also, chip will have to be burnt to allow for the cams and whatever gears you have in the rear end
the question is will i have any problems with the heads being shaved? does anyone have their heads shaved? please help
i dont know why he shaved the heads? i bought the whole kit-n-kabootal at once. the guy i bought it from said he had the same set-up on his car w/ no problems. but i have tryed to call him since i got it all home and cant get a hold of him. imagine that!! thanx guy for all the help. i have the motor at delk perf. in lebanon, tn they are going to check it out 4 me
