Piston grinding for clearance
I may need to grind the reliefs a little to make the .80 intake and .100 exhaust clearance requirement on my setup since I'm using the stock pistons for now.
I'm going to be using AFR 165's/61cc and either the TFS Stage 1 or E-303 Cam with 1.6 rockers.
Just kinda trying to plan ahead for any speed bumps, wasn't sure if the hyperuetic pistons were to be treated differently than forged pistons. I heard somewhere that the hyperuetic alloy is somewhat brittle? Certainly don't want to try to modify the relief and totally ruin a piston :notnice:
younot gonan need to notch the pistons with those cames adn those heads... they have a 1.94 intake valve youll be alright with a e303 or trick flow stage one cam.....btu anyways I just notched my pistons in my 91GT with a tool isky sells its around $150 for the tool, i got professional results and my car lives again with a trick flwo stage 3 cam in it!!
