so i plan on running an alpine type R, and the Alpine MRP-M450 amp. I am a little confused on where to run the sub signal wire to. can someone tell me the best spot to wire to?
yeah if you have a stock HU, then i would go buy a LIne converter, you can pick it up anywhere and tap into the wires going into your L and R rear speaker. if your running your amp mono you will only need to tap into one speaker
iv got an aftermarket h/u, an dim only running one sub, mono amp. where do i tap into the speaker wire? after its amplified by the stock amps, or before?
i was planning on my HU to power the 2 2way and 2 4way speakers i plan on running, then the amp will power the sub. Should i run another amp to supply my other speakers so they get some more juice?
