plastic quadrant
  • Thread starter Thread starter Mustang_Punk
  • Start date Start date Jun 28, 2007
Mustang_Punk
224
Sac, Ca
Jun 28, 2007
  • Jun 28, 2007
Does anybody know what the part number is for the small plastic gear on the clutch quadrant? I desprately need this and PnP has no t-5 cars
or if you have this small quadrant gear with the spring I will pay just about anything for it
HISSIN50
34
129
Jun 28, 2007
  • Jun 28, 2007
Dare we ask why you're not going with aftermarket pieces?
Resto houses will be your best bet for NOS or reproduction parts if you have yourself set on those POS parts.
Good luck.
cenok is family
1,409
69
79
Norman, Ok
Jun 28, 2007
  • Jun 28, 2007
get an aluminum one man so you don't have to worry about whatever trouble you're going through right now ever again.
Mustang_Punk
224
Sac, Ca
Jun 28, 2007
  • Jun 28, 2007
the big part I have is aluminum, but it didn't come with the prawl gear
bill302
2,131
alabama,gadsden
Jun 28, 2007
  • Jun 28, 2007
you dont need it the quadrant you have has two holes which line up and are placed onto the shafts the old quadrant and prawl was removed from...
Sicarius428
2,085
Jun 28, 2007
  • Jun 28, 2007
The gear is uneeded with the aluminium quadrant. It's there on the stock unit to give some adjustability but you might as well get a firewall adjsuter which is much better and less prone to wearing out like the stock unit.
Kevin
cenok is family
1,409
69
79
Norman, Ok
Jun 28, 2007
  • Jun 28, 2007
you don't need the pawl with any aluminum quadrant, regardless. i have the pro-5.0 quadrant which has only one hole. the other side rests against the second post that the pawl used to go on. SOOO much easier to install! and the firewall adjuster that comes with it is NICE. here's a pic.
Mustang_Punk
224
Sac, Ca
Jun 28, 2007
  • Jun 28, 2007
aww damnit! so i was sweating and swearing at the junkyard for no reason!
HISSIN50
34
129
Jun 28, 2007
  • Jun 28, 2007
It's no biggie - the end result is you don't need the POS. Imagine if you were still needing it................. and all the swearing when you tried to install it. Kinda sounds like something I'd do (I'm really big into mashing round pegs into square holes).
Sicarius428
2,085
Jun 29, 2007
#10
  • Jun 29, 2007
  • #10
I didn't even think about installing a stock one back in. Good lord... if you thought getting one out was a pain...
Kevin
Mustang_Punk
224
Sac, Ca
Jun 29, 2007
#11
  • Jun 29, 2007
  • #11
luckily the pedal assy. is out, good lord I can only imagine how impossible it would be to get that back in there!
Drivetrain Broken clutch cable- what it looks like
  • JulianR
  • Aug 6, 2026
Fox 5.0 Mustang Tech Aug 10, 2026
gkomo
Front window issues
  • bruno
  • Nov 7, 2026
Fox 5.0 Mustang Tech Tuesday at 10:26 PM
AeroCoupe
  • Locked
Drivetrain Adjustable clutch cable questions
  • Scott_S
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Engine Stalls when downshifting/coasting
  • Scott_S
  • Nov 5, 2025
Fox 5.0 Mustang Tech Nov 6, 2025
Mustang5L5
