- Jun 29, 2006
- 248
- 1
- 18
I received an email from my mechanic who works on the side for me and I can never understand what he is saying because of how ignorant I am about cars
Anyway, he wrote me this...
I changed the oil in the tranny. The stuff that came out had some "silver shine" or small amount of metallic flakes. More than likely the blocking rings ,shifting forks and some gears are showing there wear. I do think when we put the clutch in that will help the shifting a lot. I t is hanging up on the Throw out bearing, that is why its getting harder to push in the clutch pedal. Probably the Front Input Housing wear the throw out bearing rides is getting burrs and scratched. May be lack of grease in throw out bearing hub?
Additional note, I took the shifter out to fill the tranny oil(there may be some oil burn the header on pass. Side- spilled on it.) and found that one of the spring bushings is gone. Also I do not know if this tranny uses a nylon bushing(isolator) between the bottom of the Shift Rod to shift rail, but there is not one in there?...
can someone answer those questions and explain to me what this means? I will relay the info to him.
Thanks,
jim
Thanks,
jim
