Please help get the stang going again!!!
97gsr
31
ok i have been searching for a long time trying to figure out what is going on with my car. it runs like crap and smells extreamly rich. the firing order is correct and i am getting good spark at all plugs. all of which is new (plugs, wires, cap, rotor, and coil). i put a noid light on my injectors and they seem all fine. after the car has been runing for over a minute and take a heat reading of the exhaust at each exhaust port and cylinders 3,4,7,8 are all above 300 degrees and cylinders 1,2,5,6 are all near 110 degrees i can not for the life of me figure out what is going on. the car is a 1988, 347, with mass air and 24lb injectors. not sure if this could be releated to the map sensor or not but i am out of ideas. any help woulb be great. i don't care if i have to take it some where either anymore. if that is the case i am not too sure of any shops that would be capable or want to doing this.
Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
