Please Help O2 Sensor Hookup 5.0 Swap
Tbird8850
Okay so this may be a little long but want everyone to know the story behind the car so any answers I get will have the whole story. Its an 88 t-bird turbo coupe with a 5.0 swap. When the car was first swapped it was a 5 speed car and now has a built AOD in it. The issue is the car breaks up and boggs down to what seems to be fuel starvation only at wot. Up to 3/4 throttle car runs good and idles well. What I know is the car used to be supercharged running a Paxton unit. I believe that is why it ran fine before. The o2 sensors are disconnected forcing the computer to run in open loop and the boost would mechanically force fuel through the use of the FPR at wot but now there is no forced induction no added fuel pressure and therefore I think this is my issue. If my o2 sensors were connected it would run better in closed loop. Now the car still has an A9L computer and I have read about frying the computer issues due to the computer getting power through a port that is supposed to see ground from a neutral switch. What can I do to make my setup work? I am willing to make up a harness or whatever I just need to know if its doable and howbto hook it up? Power or ground or???? Any help would be appreciated.
  • Sponsors(?)
Tbird8850
I should also include the car has 24lb injectors, a 90mm mass air calibrated for the injectors, a fenderwell cool air intake, gt40 upper and lower, Mac flowpath headers, xpipe with flow masters and dumps. When I tried setting fuel pressure at a normal base 36, 38 or so it breaks up lower in the rpm range in order to run up to 3/4 throttle I am running 44 lbs fuel pressure at idle which makes it boggish down low. hElp:bang:
Search out @jrichker on this forum- he has every fox wiring schematic posted you will ever need to build your harness
Thanks I reached out to him.
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,380
2,719
234
75
Dublin GA
lowendmac.com
The problem is with the O2 sensor harness and how the start circuit is wired through the O2 sensor harness.
Here's what I know so far.
O2 Sensor harness interchange and modification
Originally Posted by 302EFI
Revised 16-Oct-2011 to add O2 sensor harness warnings
The wires for the 02's and low oil did not change throughout the years, they are all in the same place.
The main ones you need to worry about are (on the harness end (ECU) that plugs into the 02 plug) is:
\- 1. Lightblue / yellow
- 2. White / Purple
- 3. Purple / Yellow
The White/Purple & Purple/Yellow gets looped for a automatic ECU
The Purple/Yellow & Lightblue/Yellow for a manual ECU
Not all wires are shown for clarity and simplicity
See http://forums.corral.net/forums/gen...manual-auto-differences-year-differences.html for more O2 sensor wiring harness info
Basic premise to use with transmission swaps:
Only run a 5 speed trans O2 harness with an A9L. Do not run an Auto O2 sensor harness with an A9L. Doing so will damage the computer’s internal signal ground.
Only run an Auto trans O2 sensor harness with an A9P in a car that has an Auto trans. Using a 5 speed trans O2 sensor harness with an Auto trans may cause no crank problems.
See http://www.stangnet.com/mustang-forums/749974-computer-issue.html#post7490537 for Joel5.0’s fix to the computer internal signal ground.
The 4 cylinder O2 harness uses 4 wire O2 sensors. It probably won’t work correctly without modifying it.
Tbird8850
OK so I bought and auto sensor harness on eBay and I am going to pick up a c3w auto EEC this weekend. The harness does not exist in the car currently. If I plug in the c3w it should run how it does right now correct? Then all I would have to do is install the o2 harness and tap in wherever I need to? How will I need to tie in the harness for the o2 sensors?
Sn95 bryqn
Active User
Feb 18, 2016
11
Where is the sn95 o2 sensor harness ground location and where should it be connected ?
jrichker
Mar 10, 2000
27,380
2,719
234
75
Dublin GA
lowendmac.com
The O2 sensor ground is in the engine mounted fuel injector harness. It gets grounded to the back of the passenger side of the cylinder head or to one of the lower intake manifold mount bolts.
See the graphic for the 10 pin connector circuit layout.
The following are diagrams courtesy of Tmoss & Stang&2birds
Engine mounted fuel injector harness
Location of the TPS, IAB, and the 10-pin connectors on a 5.0, picture by TMoss:
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring; http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
94-95 Mustang wiring diagrams
http://www.veryuseful.com/mustang/tech/engine/#95-95Diagrams
Complete computer, actuator & sensor wiring diagram for 91-93 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Ignition switch wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustangO2Harness.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pin out
Fuse box layout
Mustang 5.0 Lights and Radio schematic, by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/mustangFoxLights-Radio_diag.gif
87-92 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang87-92 PowerWindowWiring.gif
93 power window wiring
http://www.veryuseful.com/mustang/tech/engine/images/mustang93PowerWindows.gif
T5 Cutaway showing T5 internal parts
http://www.veryuseful.com/mustang/tech/engine/images/5_Speed_Cutaway_Illustrated.jpg
Visual comparison of the Ford Fuel Injectors, picture by TMoss:
http://www.veryuseful.com/mustang/tech/engine/images/Ford_Injector_Guide.jpg
Convertible top motor wiring http://www.veryuseful.com/mustang/tech/engine/images/mustang88VertTopMotorCkt.gif
http://www.veryuseful.com/mustang/tech/engine/images/mustangEngineHarness.gif
http://www.veryuseful.com/mustang/tech/engine/images/TPS_IAB_Pic.jpg
Starter circuit
http://forums.stangnet.com/attachment.php?attachmentid=21328&d=1080916057
Alternator diagram for 94-95 Mustangs.
http://www.veryuseful.com/mustang/tech/engine/images/Mustang-94-95-Alt.gif
Reactions: RaggedGT
fredfifty
Well-Known Member
Nov 23, 2011
318
60
59
SF Bay Area
im getting conflicting info..that o2 sensor looped wire for the t5 looks to be for years 88-90 according to this website http://ponyperformance.com/ (go to technical and scroll all the way down to the o2 sensor harness identification). years 91-93 have a different looped wire (see diagram in attachment in the link)
who is right?
