Please help on getting GT40 irons prepped.....
BYRDPE
1,556
Memphis,Tn.
I have a set of GT40s that I bought used but they have new springs and have been cleaned up.
I am not sure of the spring rate so I'm hoping the shop can tell me this.
I'm going to send them to a machine shop to be checked out and possibly ported and polished.
What I need to know from you is what to have done to them for maximun potential.
I would also like to have the compression bumped up a tad but again I'm not sure what compression ratio I should be shooting for.
These heads will be coupled with a Cobra Intake (lower ported hopefully by TMOSS) and a OTS cam that I need your sugesstions on also.
I have a set of 1.7 roller rockers that I'm hoping to use also.
I'm hoping to make around 265-270 RWHP.
Is this possible with the parts I have?
I'm open to all comments and sugesstions.
If possible I do want to use the parts I have on hand as this will be a budget build-up but I will consider changing.
Bottom line with the machine shop is I need to know what to ask them to do to my heads.
Thanks
i did my own port job on my gt40 irons. its not hard to do at all if you got a lil patience. just match up the intake gasket.... usually a fel1250. paint the dye one the surface of the intake side and scribe your line from the gasket. then take a good porting burr and bring it out. just take measurements to keep the runners equal. also, i wouldnt do any bowl work as that could mess up the swirl if you dont know what to do. a very good thing is getting rid of the ridges down in the valve area. blending those casting lines will make a difference. just run your fingers in the ports to feel the ridges and youll find the rough spots. just watch the mating surfaces and the valve seats if you dont plan on doing another valve job. a little gaphers tape will go a long way in make sure you have warning before you do damage. after its all done just take a sandpaper like bit and clean it all up. you'll save hrs of pay for the shop and you'll feel better about your abilities after. just make sure you have a decent amount of time to spend. a good guide to go by if your looking to do some basic work and mess around with alot better flow numbers is by getting the book mustang performance. they have a pretty good guide on how to setup your heads for decent flow, and valve guide shaping.
Have them valve jobbed, and at that point the shop will check the seat pressure.
Don't go spending much more than that, because it will add up so quickly that you'll have the amount of money in them as better aluminum heads that will make more power and have more potential.
Here in NJ, a good valve job is about $200, milling is $100, then porting is $250+.
Not the most cost effective way, to spend $550 on $300 heads.
So spend the minimum, and don't waste money on porting them. Home porting is not for everyone either, just because one guy is good at it, doesn't mean everyone is.
i only bowl ported mine, smoothing out the transitions from the rough casting to the machined throat of the valve opening. i did not port my runners or gasket match. modern heads are made with swirl effect designed into them, and its best to leave that alone unless youre a pro and have a serious flowbench. still, bigger doesnt necessarily mean better. you can open up a port to flow 300cfm by just enlarging it, but you end up killing velocity and ruining the performance of the head by making it lazy. so i just did a bowl blend, had the heads milled .030 to up some compression, then a valve job and some comp springs. my GT40's were essentially free, so i didnt mind putting $300 in them
I just had mine done. 3 angle valve job, bowl work and .010 shaved off. $500 out the door. Spring pressures came in at 110 pounds. I picked the heads up for $300 and they already had Manley 1.85/1.55 valves in them. I know $800 sounds like a lot for GT40Ps but this is a budget job and that's about $400 less than a set of new aluminum heads would cost.
Actually the GT40s will pull hard against the aftermarket aluminum Heads on a n/a car!! Ported and polished.. they will rock!! Then look at the cost, Valve job.. 175.00 surface.. 65.00 performance springs... 180.00 ( with moly retainers and keepers) and you still need the port work!! Gasket match here is 250.00!! "PORT" work is up from there... add bowl and throat work.. and yes, the price is there!! BUT, there are places that will do the whole job for less as a package deal!! Take a look!! and check them out!!
Just me..............................................
Thumper
I have 94 Lightning GT 40 irons on my 82. I had them milled 020, a 3 angle valve job, and installed some Comp springs. I am still using stock rockers, and have not ported them.
With that, they have run high 12's on the motor. I have been pretty satisfied with them.
Thumper
You have mail...........
