Please help wiring problem
bluelx347
61
chicago
I recently finished my 85 conversion to a 91 interior and after rewiring the headlights everything seemed to be fine. I then pulled dash out to install a roll cage and after re-installation of the dash, the low beam headlights come on whenever the key is in the on position. I already unplugged the headlight switch and multifunction switch to see if that was the problem and no difference. There is power red and black wire that goes to the headlights. Any ideas of what is going on. Thanks, Dan
Ah man..I hate those gremlins. I would just pull the dash back out. You may have accidently pinched a wire somewhere. Check the multi funciton switch first. Make sure the contacts are nice and clean...sometimes they get green and corroded.
