please help!!
  • Thread starter Thread starter Stang347SC
  • Start date Start date Aug 7, 2005
Stang347SC
San Jose,Ca
Aug 7, 2005
  • Aug 7, 2005
hi i have an 89 LX that was converted from 4 cyl to V8. Heres the mods.. 70mm BBK TB, cobra upper n lower intakes, E303 cam, mac shorty headers,electric fan, and stock heads... i also have a bigger than stock maf.. not quite sure wat size... Well anywayz here r some problems... when driving at high rpms or high speed if i come to stop or let off the gas... its starts to die until eventually it dies out.... also i dont know but my friend suggested that maybe it stilll has a 4cyl wiring harness and thats why it might be acting funny... the reason he says is because we only found one plug for an o2 sensor... we didnt plug it in because we didnt want one side to be running richer than the other... also it has an 8LD computer.... ive looked around but havent found any info on this computer i just keep hearing A9L... it might be an issue because we suspect the car used to be automatic as well...also when cruising at low RPMs the car gets real jerky... could it be the clutch...? also recently i noticed that i can turn on the car without pushing in the clutch....? any ideas? well the bottom end of the motor is gone as the motor is knockin but that happened recently.... it wont let me past like 3.5k rpms the engine cuts off... well all the above problems astarted before the enginge knock except for the engine cutting off... any help/ or suggestions would be greatly appreciated... thnx also i am going to be buying a used engine with about 80k miles and im going to swap the c/i . i plan on getting aluminum heads but that will be for a couple of months.... i plan on goin maybe wit some gt40p heads for now.... i was planning on upgrading to the F cam... is that a bad idea...? i like the E cam but i want somethign a little more choppy... i plan on running nitrous too...
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Aug 7, 2005
  • Aug 7, 2005
the car has to have a V8 harness in order for all the engine stuff to be hooked up , or else you would have only 4 injector plug ends and the engine wouldnt run like that , sounds like to me you just need a V8 computer and it should be fine after that , and the oxygen sensor harness it seperate from the computer harness so I think you would need to get that harness as well so you have both o2 sensors plugged in and working properly , you might find the plug there if you look harder for it , since if they swapped the whole harness from the computer they probably got it from a junkyard and they should have gotten all of the right plugs and all for it for the o2s ... it might be hidden under the car somewhere ......they need to be plugged in , both of them ........
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
H
1995 cobra engine noise help
  • Holt2010
  • Nov 8, 2026
1996 - 2004 SN95 Mustang -General/Talk- Nov 8, 2026
Holt2010
H
G
Sup. Just got back into the game with a 1986 4-eye vert.
  • GeorgeG
  • Nov 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 7, 2026
limp
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
